Header to cat bolts frozen, quick question
Old May 31, 2006 | 08:52 AM
RGoose18's Avatar
Default Header to cat bolts frozen, quick question
Is it possible to take the header off w/ the cat attached?? I can't for the life of me get these bolts to break loose, I don't want to have to cut them but that's my next step. Any help would be appreciated
Old May 31, 2006 | 09:10 AM
Willard's Avatar
Default Re: Header to cat bolts frozen, quick question (RGoose18)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RGoose18 &raquo;</TD></TR><TR><TD CLASS="quote">Is it possible to take the header off w/ the cat attached?? </TD></TR></TABLE>
yes
Old May 31, 2006 | 09:13 AM
RGoose18's Avatar
Default Re: Header to cat bolts frozen, quick question (Willard)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Willard &raquo;</TD></TR><TR><TD CLASS="quote">
yes</TD></TR></TABLE>
Thank you sir
Old May 31, 2006 | 09:17 AM
Willard's Avatar
There are 3 bolts on the header so you can also break it loose that way... then pull it off of the head.
Old May 31, 2006 | 10:07 AM
Sehc Tib Alli Zerif!!!!!'s Avatar
cool guy name
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Willard &raquo;</TD></TR><TR><TD CLASS="quote">There are 3 bolts on the header so you can also break it loose that way... then pull it off of the head.</TD></TR></TABLE>
I'm not following?
The two spring bolts connect the header to the cat, then you have the 3 nuts that attach the cat to the b-pipe..
Ohh now I'm thinking with the stock header. Yes now I get it! I hate messing with those bolts though!
Old May 31, 2006 | 06:11 PM
HondaHemp's Avatar
Try heating them up until there cherry....After that, very easy to get off. A torch does wonders as long as you don't blast off some metal.
Old May 31, 2006 | 06:14 PM
citrus3000psi's Avatar
You've got a alot of options.
But first have you actually tried getting some good pentrating lube.
This stuff works wonders and its amazing to find how so many people don't use it.
If you can't get the bolts loose then you just aren't pushing hard enough. You should be able to bust/break them. If they are truely suck.
Old May 31, 2006 | 08:58 PM
JjuuN R's Avatar
Default Re: Header to cat bolts frozen, quick question (citrus3000psi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by citrus3000psi &raquo;</TD></TR><TR><TD CLASS="quote">You've got a alot of options.
not everyone is as buff and you and i!1 j/k, but on the serious hand the torch does good, just keep the flame off the bolt, it'll take it a little longer to heat up but prevents it from breakage. and of course if you try this, don't touch it
Old Jun 1, 2006 | 06:54 AM
IN VTEC's Avatar
Default Re: Header to cat bolts frozen, quick question (HondaHemp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaHemp &raquo;</TD></TR><TR><TD CLASS="quote">Try heating them up until there cherry....After that, very easy to get off. A torch does wonders as long as you don't blast off some metal.</TD></TR></TABLE>
We heat up exhaust bolts to remove them at the dealership. It's the quickest way to loosen and remove them IME.
L'motaHB
Nov 17, 2007 01:46 PM
prelude_93vtec
Sep 3, 2007 12:08 PM
hoehouseworker
Sep 29, 2004 08:31 PM
ikan
Sep 16, 2004 10:01 AM
BlueIntegraBoy
Aug 16, 2003 08:44 AM
