shifter rattles when moving in gear
Old May 31, 2006 | 08:44 AM
theshaunanana's Avatar
Default shifter rattles when moving in gear
Just like topic says..its really annoying and the only way it stops is if I put it in nuetral or keep my hand on the shifter..anyone know why it does that and how it can be fixed? I have a 1990 civic hatchback dx
Old May 31, 2006 | 08:46 AM
Suck my DX's Avatar
Default Re: shifter rattles when moving in gear (theshaunanana)
might be hitting your exhaust......might be loose....get under the car and take a look
Old May 31, 2006 | 11:00 AM
ludesrv's Avatar
Bushings die on those. Get some poly urethane ones. The kit is like 15$ from energy suspension and works like a beauty. Nicer and stiffer then stock bushings. They don't wear down as fast and they really hold the stick in place. There is no play in the stick normally when you do it. It's sweet.
Old May 31, 2006 | 11:23 AM
emwavey's Avatar
Default Re: (ludesrv)
ditto on the bushings... had the same problem and the bushings solved it.
Dougall
Aug 27, 2012 05:48 PM
Diversion
16
Aug 10, 2009 12:57 PM
Tweakmeister
Jun 14, 2009 07:45 PM
M15
Nov 8, 2005 06:03 PM
