How do you fix a stripped head bolt hole?
Old May 31, 2006 | 07:45 AM
vodkas22's Avatar
Default How do you fix a stripped head bolt hole?
I have an ls vtec set up with one stripped bolt hole for the head bolt. How do I go about fixing it? Any advice would help. Thanks.
Old May 31, 2006 | 08:01 AM
Marauder's Avatar
Default Re: How do you fix a stripped head bolt hole? (vodkas22)
http://www.sears.com/sr/javasr...e=Yes
Old May 31, 2006 | 08:34 AM
vodkas22's Avatar
Default Re: How do you fix a stripped head bolt hole? (Marauder)
I have the bolt out, but the bolt hole is stripped...how do I fix that?
Old May 31, 2006 | 10:39 AM
vodkas22's Avatar
the hard part is the hole is so deep, so there's really no way of getting that bottom piece of the heli-coil out.
Old May 31, 2006 | 01:05 PM
Top Ramen's Avatar
Can you get a Timesert in there?
Old May 31, 2006 | 01:52 PM
Brent L's Avatar
timesert is the answer
Old May 31, 2006 | 03:32 PM
vodkas22's Avatar
Default Re: (Brent L)
The new problem is that so much of the thread is stripped that the hole is bigger than the drill bit for the tap and die to bring it back to stock threading. The only other route would be to make the hole bigger which would cause problems because of the head gasket. Anyone else know any other solutions?
TylerH2006
Apr 29, 2007 02:00 PM
Serdar
Aug 18, 2006 11:39 PM
redm3turbo
10
Jul 20, 2006 01:36 PM
JDM Vision
May 25, 2006 03:38 PM
chriskona
Welding / Fabrication
Feb 15, 2005 06:47 AM
