95 GSR clutch issue
Old May 31, 2006 | 06:47 AM
pskkd930's Avatar
Default 95 GSR clutch issue
Hello,
I have a 1995 GSR with 160k miles on it. This weekend the clutch starting catching really low and on Tuesday(after sitting for three days) it wouldn't engage at all. I checked the fluid and it was a bit low. Added more and it seemed to work ok.
Since then, the clutch seems to have lower resistance and catches low only after the car has been sitting for a while. If I drive it for a bit, it seems to go away. I've checked the fluid levels again and they are level(aka I'm not losing anymore). I'm a little perplexed. The fact that the car seems to drive different after sitting for a while is new to me.
Any suggestions?
Thanks!
Old May 31, 2006 | 07:17 AM
DC2 Mang's Avatar
Default Re: 95 GSR clutch issue (pskkd930)
try bleeding your clutch line out
usually when clutches go out the hardly grab and/or slip very easily especially when you are slamming gears
it could possibly be your clutch mater cylinder
Old May 31, 2006 | 10:30 AM
ckyguy's Avatar
I could also be the clutch springs, but I would also lean towards bleeding the clutch first.
dsmgurrl
Sep 18, 2008 05:14 PM
Telix
Sep 6, 2006 04:41 PM
wreckedmyteg
Dec 9, 2004 04:04 AM
Simple
May 15, 2004 12:17 PM
