I need help with the A/C compressor oil
Old May 31, 2006 | 06:16 AM
maivla01's Avatar
Default I need help with the A/C compressor oil
i'm replacing the A/C compressor for 94 honda accord ex, but i don't know what kind of oil i should use for lubrication. BY the way the A/C compressor branch is HADSY...ANY IDEAS OR OPTION?? thanks in advanced.
Old May 31, 2006 | 10:32 AM
Hondaman56's Avatar
From: Filthadelphia City of Brothers and Love, PA, USA
Default Re: I need help with the A/C compressor oil (maivla01)
I believe you will need PAG-150. If you had a compressor failure you will need to flush the entire system to remove all of the crap that was run through the system as the compressor disintegrated over time. This requires disassembly of just about everything. Be sure to replace all O Rings in all lines, and replace the dryer. I also replaced my condensor just to be sure. Flush all lines using brake cleaner and compressed air. Its not an easy job, but can be done and you'll save a few bucks. My shop wanted $1400 to do the job and I did mine for $900 after having to replace one of the high pressure lines that got old and ruptured costing me an additional $229. Count on a shop charging $100 to vacume/evacuate the system, pressure test and charge the system properly after your work. Tell them you havel already installed PAG oil or they will do it again when they charge the system.
These sites were VERY helpful when I was in the dark and had no idea how to rebuild an AC system.
http://www.geocities.com/micro....html
http://www.autoacforum.com/
Modified by Hondaman56 at 7:42 PM 5/31/2006
SW20FL
Jun 25, 2015 04:47 AM
FreshPaint
Aug 2, 2011 08:04 PM
1990AccordEX
Sep 1, 2009 02:51 PM
JBirch_97Prelude
Jun 7, 2008 02:32 PM
cdfran
Mar 23, 2008 10:11 AM
