z-10 block plug
Old May 31, 2006 | 04:45 AM
RTW DC2R's Avatar
Default z-10 block plug
does it just pop in? I see it has 2 rubber o-rings on it but it came with no installation info. I would assume the internal block pressure would be enough to pop it out but have no idea.
Old May 31, 2006 | 05:24 AM
underpressure02's Avatar
Default Re: z-10 block plug (clip the apex)
It just pops in. I doubt you will build that much crank case pressure to pop that ****** out. I had to hammer mine in.
Old May 31, 2006 | 05:32 AM
RTW DC2R's Avatar
ok I wasnt sure how hard it is to get in. still waiting for the block to get here. thanks
Old May 31, 2006 | 06:50 AM
mstolars's Avatar
Default Re: (clip the apex)
I put some honda bond on mine, but it is a really tight fit(had to bang it in with a mallet), so I think if you just put it in dry, you shouldn't have any problems.
Old May 31, 2006 | 07:06 AM
kordenbrock motorsports's Avatar
honda bond will help. the ones that we make for our crankcase vents utilize the factory mounting hole (we weld a tab and drill a hole for mounting it in the stock location of the charcoal canister) works well, no issues on the 4-5 we've done.
brett
Old May 31, 2006 | 09:46 AM
92cxturbo's Avatar
Default Re: (kordenbrock motorsports)
Old May 31, 2006 | 09:48 AM
turbotime's Avatar
Default Re: (92cxturbo)
yeah i got my freezer plug for 0.15, i called z10 and when they wanted 25 for that plug i just laughed
crazy people
Old May 31, 2006 | 10:30 AM
RTW DC2R's Avatar
if I knew there was a cheap way of doing it, I would have went that route. Im not even sure how much they charged me, Ill have to check.
Old May 31, 2006 | 10:34 AM
turbotime's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clip the apex &raquo;</TD></TR><TR><TD CLASS="quote">if I knew there was a cheap way of doing it, I would have went that route. Im not even sure how much they charged me, Ill have to check. </TD></TR></TABLE>
yeah both ways work, but the z10 is removable, the cheap way is permenant. My buddy got the z10, its a nice piece just sucks no one will ever see it
Old May 31, 2006 | 11:37 AM
JDM_Risa's Avatar
Default Re: (turbotime)
its a really nice piece... i plugged mine with the hardware that came with the endyne catch kit from http://www.theoldone.com...i had to hammer it in too at first i thought that it would prolly build pressure and shoot out but so far so good...
Old May 31, 2006 | 12:03 PM
splitime's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbotime &raquo;</TD></TR><TR><TD CLASS="quote">yeah both ways work, but the z10 is removable, the cheap way is permenant. My buddy got the z10, its a nice piece just sucks no one will ever see it </TD></TR></TABLE>
Freeze plugs are not permanent last that I checked. Its just annoying to find the right size normally.
Old May 31, 2006 | 12:09 PM
Tchleung's Avatar
I'm using the Z10 plug. very ncie piece with 2 o rings. It was so tight tog et in. I had to tap it in with a mallet. Seels perfectly tho!
Old May 31, 2006 | 01:01 PM
mike1114's Avatar
Default Re: (Tchleung)
Hell....Z10 even sent me two, so technically, I got mine for free!!
Yeah Z10!!
Old May 31, 2006 | 04:47 PM
D-meet07's Avatar
Default Re: (mike1114)
where can you get one for 0.15??? curious. I would think that you could use some type of platic cap with some gasket bondo and boom.....good to go.
IntegraType-R
May 3, 2007 08:56 PM
TypeSLO
Jul 22, 2006 07:50 AM
TylerB
13
Apr 23, 2006 03:58 PM
