Is this an 88rcx si harness?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ak_ef9 »</TD></TR><TR><TD CLASS="quote">anybody else? and i alraedy have a 91 si harness</TD></TR></TABLE>
then use that
then use that
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brijpurt13b »</TD></TR><TR><TD CLASS="quote">NIGA DAT IZ A 88 SI HARNES DAT IZ Y IT DUNT FIT DA 88 SI HARNES HAV DIFERNT FIERWALL CONECTOR SO IT WUNT WORK,,NIGA I GOT 90 SI HARNES IF U NEED</TD></TR></TABLE>
are you serious?
are you serious?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brijpurt13b »</TD></TR><TR><TD CLASS="quote">IF U GOT 91 SI HARNES US IT LIKE I SED DA 88 FIERWAL CONECTORS R DIFERNT DEN 89,90,91</TD></TR></TABLE>
your joking, right??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brijpurt13b »</TD></TR><TR><TD CLASS="quote">NO IM NOT FIERWAL CONECTORS R DIFERNT BEWTEN YEARS 88 ---89,90,91 I NO CUZ I TRY IT BEFOR AN IT DID NOT WORK</TD></TR></TABLE>
haha ok its not funny anymore, you can speak english now.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdminthemakin »</TD></TR><TR><TD CLASS="quote">
then use that</TD></TR></TABLE>
I am but I want to sell the one I had so I am trying to figure out what it is before i go selling it to someone else
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by droppedcrxsi »</TD></TR><TR><TD CLASS="quote">thats a da harness</TD></TR></TABLE>
not doubting you, but how can u tell? (for my own curiousity)
its obd0... so its 90-91 teg. Its a b series injector config. and the most obvious is the fact that is has 3 plugs at the drivers side shock tower... See the injector box plug(green), the white 6 pin, and the big 14 pin? thats a da harness only.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by droppedcrxsi »</TD></TR><TR><TD CLASS="quote">its obd0... so its 90-91 teg. Its a b series injector config. and the most obvious is the fact that is has 3 plugs at the drivers side shock tower... See the injector box plug(green), the white 6 pin, and the big 14 pin? thats a da harness only.
holy crap, you know you've been around harnesses alot when...
</TD></TR></TABLE>holy crap, you know you've been around harnesses alot when...
Thanks bro. I didnt even see your post. I will get my money back from the person that told me it was an si harness
</TD></TR></TABLE>Thanks bro. I didnt even see your post. I will get my money back from the person that told me it was an si harness
okay so a wire harness from a hf 1989 crx will not work on a 1989 honda crx si because i put my si moter in the hf and it wont stared so some one toled me i need to change my hole wire harness is that true ?
