88 si shell w/ 90 si harness problem *searched plenty*
Im puttin a b16 into an 88 si crx shell. The 90 si engine harness has a round 8 wire plug , while the 88 si body harness has rectangle 6 wire plug and then a 2 wire plug closer to the headlights. The pic is pretty explanatory. I thought about just matching up the colors but theyre different. Also the small 2 wire plug has a brown and bule wire, while the 6 wire rectangle plug also has brown and blue wires. Has anyone ran into this issue or have a wiring diagram I can check out. wat is that round plug for anyways?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx_88_si »</TD></TR><TR><TD CLASS="quote">the 2-wire plug is the service connector for timing adjustments. FYI</TD></TR></TABLE>
cool man
but then where are the 2 other wires then that i need to make 8 . arrgh. ill just go hunt for an 88 si harness
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Suck my DX »</TD></TR><TR><TD CLASS="quote">u need an 88 engine harness</TD></TR></TABLE>
wow. youre a real genious. how bout you go find me one . thanks
cool man
but then where are the 2 other wires then that i need to make 8 . arrgh. ill just go hunt for an 88 si harness<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Suck my DX »</TD></TR><TR><TD CLASS="quote">u need an 88 engine harness</TD></TR></TABLE>
The wires that make it a 8 pin connector are for the fast idle valve... 1 wire is blue, the other is blk/yellow... eliminate those, and match the rest of the wires... You should be good... I THINK thats the only difference... I have never tried this on a car however to verify(weird I know!)
Ryan
Ryan
If you gimme the exact wire colors, I'm holding both of your engine wiring diagrams in my hand. I'm pretty sure ryan is right though. Although on your car there is a dashpot control solenoid setup, and the wires to that are somewhere...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigcalidave »</TD></TR><TR><TD CLASS="quote">Thanks bud, and your s2k cluster converter should be here soon.
NICE!
</TD></TR></TABLE>NICE!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by droppedcrxsi »</TD></TR><TR><TD CLASS="quote">The wires that make it a 8 pin connector are for the fast idle valve... 1 wire is blue, the other is blk/yellow... eliminate those, and match the rest of the wires... You should be good... I THINK thats the only difference... I have never tried this on a car however to verify(weird I know!)
Ryan</TD></TR></TABLE>
good thinkin.. 88 does NOT have a fast idle valve.. match up the wires and give her a go.
I did something similar to what your currently doing. I have a 88std model and I put a 90 civic Si wiring harness in the car, but the entire wiring harness from headlight to tailight. A lot of the plugs you can just repin them.
ICeDoUt
Nov 25, 2005 12:19 PM
H22AEG2
Oct 17, 2003 08:36 PM
chirp2hrd
10
Sep 12, 2002 10:21 AM
