Can I use any civic electrical wiring to fix
Old May 30, 2006 | 11:22 PM
Del Sol on Steroids's Avatar
Default Can I use any civic electrical wiring to fix
Can I use the front electrical wiring of a civic and use it on a Del Sol. I'm fixing my Del Sol, I had a front end collision and need the wiring, all of it but mostly for headlights. HondaAutomotiveparts.com is asking way to much.
Old May 31, 2006 | 12:18 AM
chartinael's Avatar
Default Re: Can I use any civic electrical wiring to fix (Del Sol on Steroids)
Yes you can, they in general have the same functionality. However, you might have to change out connectors in between generations. But you should have those left on your damaged vehicle. It will be best to stay within generations.
Wire colors are identical as far as I have noticed. Also, it might be a bit different in lenght and where the wire straps connect harness to vehicle body. But in general harnesses can be had for almost nothing at a junkyard ...
kristin
rudebwoy
Jun 20, 2012 10:31 PM
loveda07
Jun 8, 2008 09:50 AM
rysingsun86
Dec 20, 2005 10:17 AM
