Audio Equipment for sale!
Well I have a bunch of audio equipment in my room taking up a bunch of space. I have no needs for this equipment anymore. Heres the list:
-10in Custom Subwoofer built with a resonant engineering motor. This sub can take up 1000w RMS daily and is SVC 4ohms. Excellent SQL sub. Hasn't been used much and still needs to be broken in. NOT FOR SALE ANYMORE
-12in Alpine Type-S Subwoofer. Has a crack on the cone but has been sealed with Cyanoacrylate glue. Works perfectly. 300w RMS DVC 4ohms. $50 picked up
-12in sealed box. 1.5cubes $20 picked up
-15in Kicker CompVR Subwoofer. It is brand new in box. DVC 2ohms. 500w RMS. $100 picked up.
-Cerwin Vega SS-2693 3-way 6x9's. These are great speakers that will give you excellent treble and vocals. The dustcap was starting to fall off to I sealed it back up, works perfectly now 60w RMS. $40 picked up.
-12 ft of Tsunami 0AWG wire. Brand new $35 picked up.
-Pair of 2in Aura Microwoofers Brand new $30.
-Pair of Rockford Fosgate 4AWG ring terminals $10 for both
-Negative battery terminal takes one 0AWG and two 4AWG $15
-JL Audio 200a ANL Fuse $10
-Stinger 4AWG T-block Distrobution block $10
Here they are again.
Your best bet is to Email me at xaznkewlguyx@yahoo.com
Bump if you view
Modified by XaznkewlguyX at 1:37 AM 6/1/2006
Modified by XaznkewlguyX at 1:38 AM 6/1/2006
Bump if you view
Here are the TS parameters for the 10in:
Param. 10"
Fs 29.7 Hz 29.3 Hz 26.8 Hz 26.3 Hz
Qms 6.62 7.2 7.9 6.06
Qes 0.27 0.30 0.32 0.40
Qts 0.26 0.29 0.30 0.37
Vas 19.6 liters 44.8 liters 132 liters 230.1 liters
Re 3.6 Ohms
BL 22.8 22.1 22.1 22.1
Sd 310 cm2 514 cm2 804 cm2 1210 cm2
Xmax 25.85mm one way linear
Pmax 1000W RMS
SPL 84.6 dB 87.6 dB 91.0 dB 92.1 dB
Param. 10"
Re 3.6 Ohms
Pmax 1000W RMS
J Cruz
Northern California (Sales)
May 24, 2008 12:43 AM
