Sucked up water but dont think much
Old May 30, 2006 | 09:11 PM
A-busive's Avatar
Default Sucked up water but dont think much
Here's how my NIGHT went, me n my girl decided to go out to eat, after we came out to leave it started raining(i hardly drive b/c of my cold air intake during the rain)lightly, as i was on my way taking her home is started to pour down rain, so i was cautious as hell on not to hydrolock, so drove to the point i was holding back traffic but idc ?engine>holding up traffic? so i drove through puddles up n down city streets down n up hills i go(making sure the whole time as i was driving through puddle that i was in 5th gear, to wear as that i'm not much likely to sucked up water due to low rpm, n then i saw a puddle to late and tried to brake as much as i can, but not hard of course seeing that i was holding traffic up, i ran over the puddle (but not much was sucked in due to braking in time)and after a couple of seconds it had a minor heart attack and shut off(and their i was in the middle of the street on top of the hill holding up traffic), as everyone went by me she n i sat n waited for a couple seconds hoping that i can crank it and be on my way. After a few attempts it wouldn't turnover then i panic like hell in my mind trying to keep it kool. i turned off my radio and everything else that takes nesource of battery power and so i waited a few more seconds and started it up again, and wtf our faces shined and my engine came back to life, but of course i had to give a lil gas to keep it up when first starting back up..So i continued on to take her home b4 my blessings run out, but on the way the entire time it made tis weird nose????????BUT TO MAKE THE LONG STORY SHORT, is my engine ok and just needs to dry over night to stop the sound when i start my car, or do i need to get taken to the shop as soon as possible just in case further damage occurs????Please help, and truly apologize for the long story
Old May 30, 2006 | 09:24 PM
A-busive's Avatar
Default Re: Sucked up water but dont think much (aallbbeerrtttttt)
i hope not i just here this sound coming from under hood thats pretty loud but not much
Old May 30, 2006 | 09:25 PM
A-busive's Avatar
Default Re: Sucked up water but dont think much (A-busive)
d16z6
skunk2mani
aemv2
greddy evo2
Old May 30, 2006 | 10:16 PM
A-busive's Avatar
bump for the night
Old May 31, 2006 | 12:23 AM
teknoracing's Avatar
It should be okay, if you feel the need, give her an oil change and change your spark plugs. Take spark plugs and wires off and give her a few cranks to spew any water out, i typically stop when i can smell gas.
If your oil is still new, dump it in a bucket and by some cheap conventional oil to flush out any water, then put your regular oil in there.
Old May 31, 2006 | 02:27 AM
Syndacate's Avatar
I didn't read all of the post, I stopped at the part when u said "I drove to the point where I was holding up traffic" - I don't get it, why were u so afraid of hydrolocking? Can't u only hydrolock if water gets into the system? Usually a hood eliminates this problem at the least?
Iono, I'm kinda lost there, drive my civic in the rain all the time, I have no wiper blades either, I doubt I'ma hydrolock from that...In any event, as long as it starts, it should dry up in a night or so (starting would show that there's no perm damage)
Old May 31, 2006 | 03:28 AM
spoonracer84eg's Avatar
Default Re: (Syndacate)
He has a cold air intake
Old May 31, 2006 | 04:14 AM
black_EM1's Avatar
Community Builder
Community Influencer
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate &raquo;</TD></TR><TR><TD CLASS="quote">I didn't read all of the post, I stopped at the part when u said "I drove to the point where I was holding up traffic" - I don't get it, why were u so afraid of hydrolocking? Can't u only hydrolock if water gets into the system? Usually a hood eliminates this problem at the least?
You're kidding, right?
The motor should be fine if it started up.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teknoracing &raquo;</TD></TR><TR><TD CLASS="quote">It should be okay, if you feel the need, give her an oil change and change your spark plugs. Take spark plugs and wires off and give her a few cranks to spew any water out, i typically stop when i can smell gas.
Old May 31, 2006 | 05:28 AM
G2 Speed's Avatar
Iono, I'm kinda lost there, drive my civic in the rain all the time, I have no wiper blades either, I doubt I'ma hydrolock from that...In any event, as long as it starts, it should dry up in a night or so (starting would show that there's no perm damage)</TD></TR></TABLE>
Old May 31, 2006 | 05:38 AM
ddd4114's Avatar
Default Re: Sucked up water but dont think much (teknoracing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teknoracing &raquo;</TD></TR><TR><TD CLASS="quote">Take spark plugs and wires off and give her a few cranks to spew any water out, i typically stop when i can smell gas. </TD></TR></TABLE>
Disconnect your fuel injectors when you do this. It should get a fair amount of water out.
Old May 31, 2006 | 11:58 AM
jeremydde's Avatar
If he was able to start it up again and drive it home then there is no water in the cylinders anymore. It would have been mostly been flushed out by cranking it to start and all water vapor would have been forced out as soon as it started up. If it's making a noise it is possible be might have bent a valve or two. It would make more noise and depending on the damage still start up as well.
Old May 31, 2006 | 06:20 PM
A-busive's Avatar
Default Re: Sucked up water but dont think much (jeremydde)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jeremydde &raquo;</TD></TR><TR><TD CLASS="quote">If he was able to start it up again and drive it home then there is no water in the cylinders anymore. It would have been mostly been flushed out by cranking it to start and all water vapor would have been forced out as soon as it started up. If it's making a noise it is possible be might have bent a valve or two. It would make more noise and depending on the damage still start up as well.</TD></TR></TABLE>actually u are right on that, i went to the performance shop and he heard it and i said it sounded like a bearings,piston or rod and it may have bent a lil bit to the point which made me able to drive it off....Idc too much of what happen, im just glad im not in need of an engine...So he said it would be best to start looking for piston n rods even though i will be goin turbo this summer hopefully any suggestions
Old May 31, 2006 | 06:26 PM
Syndacate's Avatar
lmao, dude, how big are the puddles that ur CAI is gonna get soaked if u don't go slow as hell? U have to nail a puddle pretty hard to get it over the splash guard, but whateve,r 'tis why I use short rams
Old May 31, 2006 | 08:50 PM
TorquelessB16's Avatar
The same thing happened to me. After a day of drying out, it was fine. I think your chances of hydrolock are pretty slim. In civics, I don't even think water gets sucked up as much as water VAPOR gets sucked up. Think about drawing a drink up through a straw that isn't completely submerged. You don't get much drink do you?
You need like 3 tablespoons to get engine damage from the high pressure of H2O in the cylinder. But nevertheless, use shortram if you get lots of rain...or else risk this:
ouch
Old May 31, 2006 | 08:56 PM
DohcSide's Avatar
Default Re: (ZeeSix)
from experience i think your motor is a ticking bomb waiting to detonate
Old May 31, 2006 | 08:58 PM
turnsignalandy's Avatar
could i hydrablock with a removed resonator on my D16Y8?
Old May 31, 2006 | 09:02 PM
Sean @ ESG's Avatar
i spray water into my throttle body
=P
Old May 31, 2006 | 09:07 PM
evilcivilian's Avatar
hmmm i think u hydrolocked already.
I hydrolocked and it started up fine, but when the time came the engine just blew a hole in the block
Old May 31, 2006 | 09:40 PM
SeeD419's Avatar
Default Re: (evilcivilian)
bypass valve
Old May 31, 2006 | 10:25 PM
4dohs4mohoes's Avatar
Default Re: (SeeD419)
I hydrolocked my d15b a few times. It wasn't with water tho. It was with fuel. (don't ask, not important). All I did was pull the sparkplugs, unplug the distributor, and crank it till it was dry. The motor would start and run fine.
Old Jun 6, 2006 | 07:20 PM
Syndacate's Avatar
Default Re: (turnsignalandy)
Raced a 1st gen Integra with an exhaust and intake. I was driving my stock 97 4dr ex. Wasted it. Then the teg driver got pulled over for runnin a stop sign. He didnt have insurance nor his licence, $1200 ticket. I got off free
__________________________________________________ ______________________
-hey man u got a Joint?
-uh no.......
-Id be a lot cooler if u did
I got a hard time swallowing that story...the teg puts out what, 140hp? Against ur 127 (max), teg also has better compression and more displacement, more torque..
I'm sorry, u had to be either facing a teg w/ a bad engine, or a teg w/ a bad driver, u shouldn't beat a teg w/ a stock EX, it just shouldn't happen
Old Jun 6, 2006 | 07:27 PM
G2 Speed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate &raquo;</TD></TR><TR><TD CLASS="quote">could i hydrablock with a removed resonator on my D16Y8?
-uh no.......
I'm sorry, u had to be either facing a teg w/ a bad engine, or a teg w/ a bad driver, u shouldn't beat a teg w/ a stock EX, it just shouldn't happen</TD></TR></TABLE>
you can hydrolock anything.. removing the resonator.. will just make your car more annoying
jdm-style-dc2
Nov 12, 2010 10:34 AM
K20Death
Apr 30, 2006 02:25 PM
Liquid Ice NF
Aug 12, 2005 05:52 PM
MysteryWagon
Jun 11, 2003 06:58 PM
animated_life
Feb 23, 2003 04:51 PM
