extending o2 sensor wire?!??!
how would i go about doing this? can i just use anywire??? or dos it have to be special...the reason i have to do this is b/c the o2 sensor doesnt reach the bung for it to screw in...
-thanks
-thanks
I just looked around my house for that extender harness, but I can't find it anywhere
. You can't say I didn't try to help though. Sorry though I have no idea what I did with that thing.
get some 18 gauge wire, strip it, solder it to the O2 sensor wire, slap on some heatshrink tubing and crimp on a female spade connector and plug up, it will def work, i just passed smog today.
The dc sports extension harness seems to work well and it adds 2 plug connectors and extra wire. And what about people that add a 4 wire 02 sensor when converting to OBD1? I doubt their wire lengths are the same as a stock OBD1 vehicle.
I would look for a wire that has a heat resistant insulator 18guage. Just solder it.
And you will probably not need more than a foot which will not add much resistance.
I have done it on my car and I know it works!
in most cases you can split the engine harness loom and pull more of the o2 wire out. if you were going to splice i would add wire to the engine harness side this way if you need a new sensor in a pinch any sensor will fit, also if you want a longer o2 wire for some reason bosch makes 1 wires universal o2's with different lenth wires just get a long one and solder on your plug. My vote is for the engine harness extension
dropd4door
Dec 27, 2004 09:53 PM
civicmatt
Jun 22, 2003 07:27 PM
