NEEDED- 2 freeze plugs for an ls block, and a ls lower timing belt cover
title says it all, i need 2 of the plugs for the back of the block, and a lower timing belt cover. hopefully someone local to ct, i can pick it up if its anywhere between manchester and norwalk, as thats on my way to work, or elsewhere i can make time to pick them up. someone has to have a blown block sitting around that i can pirate the plugs and cover off of. i'll pay some $$ for them.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by handlebarsfsr »</TD></TR><TR><TD CLASS="quote">title says it all, i need 2 of the plugs for the back of the block, and a lower timing belt cover. hopefully someone local to ct, i can pick it up if its anywhere between manchester and norwalk, as thats on my way to work, or elsewhere i can make time to pick them up. someone has to have a blown block sitting around that i can pirate the plugs and cover off of. i'll pay some $$ for them. </TD></TR></TABLE>
I don't know if you already knew, but if this was being used in a built block, OEM honda sells breather plugs for the back to connect to a catch can.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dxcoupe. »</TD></TR><TR><TD CLASS="quote">
I don't know if you already knew, but if this was being used in a built block, OEM honda sells breather plugs for the back to connect to a catch can.</TD></TR></TABLE>
i know, but somehow i ended up with 3 breather plugs, 2 for oil and one for coolant. i need 1 oil for the catch can, but the others i need plugged.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Diego Dangers. »</TD></TR><TR><TD CLASS="quote">you can pick up a freeze plug at any auto shop for CHEAP. better to get new.</TD></TR></TABLE>
the dealer couldnt get one, so i assumed no one could get one. which shops have them?
92integraVTECgsr
May 25, 2008 07:04 AM
