motor wont turn over
Old May 30, 2006 | 06:29 PM
jdmcivicsi522's Avatar
Default motor wont turn over
heres tje problem my girlfriend brought her 94 ls out today for me to put a headunit in. so i put the headunit in start the car to make sure every thing is good and it is. then i shut the car off for about 5 maybe 10 minutes. go to start the car and it wont turn over. i think it is the starter or alternater the battery reads good on my tester but the alternater reads dead. like i said it cranks but wont turnover to start to do guys think it is the alternator starter or something else? please let me know asap
Old May 30, 2006 | 06:54 PM
BOOSTED RIVAL's Avatar
Default Re: motor wont turn over (jdmcivicsi522)
so the motor crank but it just don't start right ?
Old May 30, 2006 | 07:02 PM
Default Re: motor wont turn over (BOOSTED RIVIL)
ya
Old May 30, 2006 | 07:15 PM
blkb18's Avatar
if its cranking properly and wont start then your missing one or some of the following: air, fuel, spark, good compression. Chances are its fuel or spark.
Old May 30, 2006 | 07:48 PM
Default Re: motor wont turn over (blkb18)
there was no spark what would that be
Old May 30, 2006 | 09:43 PM
cao's Avatar
cao
k if ur alternator is dead like you said try jumping and if it jumps its ur alternator going bad and also check spark plugs or check the distubitor
- sorry for my spelling if i spelled it wrong.
Old May 30, 2006 | 10:58 PM
acurarock17's Avatar
Default Re: (cao)
spark = igniter module, distributor.. chances are, if you didn't touch the distributor, its still aligned fine, i'd ohm out your coils with a meter once you unplugged all the leads from them.
mcr1971
Jul 17, 2017 05:24 AM
kgreenhaw
Nov 21, 2009 05:03 PM
NeverLift
May 9, 2009 03:06 PM
mr devious illusions
May 20, 2005 09:56 PM
QUIKRLS
Aug 29, 2004 11:02 PM
