oil light comes on but oil level is fine?????????
Old May 30, 2006 | 06:09 PM
toyH22's Avatar
Default oil light comes on but oil level is fine?????????
i have a 97 turbo prelude and for some reason my oil light comes on every once in awhile blinking....... so I pull over to check the oil level and its fine???? I shut the car off and the oil light disapears... is my car not getting enough oil pressure??? when the light is on, I turn the car off and the light doesn't come on any more???? WTF??
Old May 30, 2006 | 06:26 PM
InvaderTrax's Avatar
Bad oil pump? Dented oil pan? Perhaps just a bad pressure switch
Old May 30, 2006 | 06:56 PM
twistedbydezign's Avatar
Default Re: (apeng09)
the oil light turns on when oil pressure dips to 7psi i think it is, which is kinda retarded since with oil pressure that low, you are already damaging things....i would get a mechanical oil pressure gauge hooked up immediately, that will tell you if the stock sensor is just fucked up, or if you seriously have a problem with the oil pressure, as someone said, a tiny dent in the right place of the oil pan will have a big affect on oil pressure if that dent is right at the pickup
Old May 31, 2006 | 11:01 AM
prelittlelude's Avatar
Default Re: oil light comes on but oil level is fine????????? (toyH22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toyH22 &raquo;</TD></TR><TR><TD CLASS="quote">i have a 97 turbo prelude and for some reason my oil light comes on every once in awhile blinking....... so I pull over to check the oil level and its fine???? I shut the car off and the oil light disapears... is my car not getting enough oil pressure??? when the light is on, I turn the car off and the light doesn't come on any more???? WTF??</TD></TR></TABLE>
oil light will flash if oil press ever drops below 5 or 6 psi and then returns.. oil light will come on and stay solid if oil pres drops and stays below 5 psi..
are you using a garden hose for a oil feed line to the turbo? get a pres gauge, and lole said before, do you have a nast oil pan dent? get a mechanical guage on there ASAP
Old May 31, 2006 | 12:28 PM
toyH22's Avatar
i have a cheap oil feed line, but im not driping oil..... My level of oil is right were it should be..... I guess i need to get a gauge to see exactly were oil psi is at. im gonna check the oil pan and the sensor today.
Old May 31, 2006 | 02:05 PM
H24A96EK's Avatar
check oil pressure
sensor wire grounding out
switch is bad
start there
TORTUGA
Oct 28, 2013 11:32 AM
Schultzie
Jul 10, 2010 08:58 PM
mtownek9
Apr 1, 2008 01:54 PM
siis2fast
Nov 4, 2005 04:54 PM
livelife46290
Jul 14, 2004 05:15 AM
