how do you tell what head you have?
I own a 90 civic SI. I bought it used about a year ago. I know that the block has d16a6 stamped on it. The valve cover was writen on by hand ZC right about the oil cap with some kind of crayon. I was curious if you guys know how I can figure out. I know that they are basically the same thing except the ecu and cam are different.
** nevermind the block wasn't stamped d16a6 i just supposed it was.
Modified by l1bid0 at 6:32 PM 5/30/2006
i dont think theres any way to tell ethier.i think cams are diff cams if u sit them sideby side and measure them. i hear si has more aggresive cam profile.then the rest.but like dude said its never been proven only hear say.
Well if the block is stamped it ZC, then it's a ZC. For future reference though and simplicity, treat it as a D16A6. And if you want to do a Mini-me, you will have to use the D15B7 timing belt due to the differences between tensioners (you can't use a proper VTEC tensioner on a non-vtec block).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vteckillenzc »</TD></TR><TR><TD CLASS="quote">wait isnt the single cam zc vtec?</TD></TR></TABLE> One version is, and it isn't labeled ZC. That is the D15B.
91 EF DX
May 24, 2013 07:34 PM
h8tred
18
Mar 31, 2003 02:27 PM
