SWAP QUESTON 99-00 B16A2 INTO 96''EK SEDAN
im doing a 99-00 b16a2 swap into my 96 ek sedan , should i just use the stock 99-00 si mounts and bolt it up ??? , are there any modifications with throttle cables ??? and what engine harness should i plug up for best results ???
thanks honda-tech
thanks honda-tech
99-00 Si mounts will work. Use your harness and modify it. If you have the Si throttle cable use it. The Y8 cable might work, not too sure.
i2ishift
Jun 4, 2009 03:38 PM
