Does the washer trick work for correcting camber on an RSX?
I took a look at the camber arm while installing coilovers, and it looks like the bolts attaching the camber arm to the chassis from the bottom instead of the side. Would I be able to insert washers between the chassis and the camber arm to correct camber?
Thanks for your input!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Todd00 »</TD></TR><TR><TD CLASS="quote">No. You need to buy a camber kit for the rear. No other way around it.</TD></TR></TABLE>
