h22 STR cam gears...
So I just bought my h22 longblock and it came with STR bronze cam gears, and the dude left timing belt off, my question is on the STR cam gears, is there a way to tell if the cams are in spec with pistons and crank??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eddiebx »</TD></TR><TR><TD CLASS="quote">u line up the str gears like any other cam gear when installing the timing belt.</TD></TR></TABLE>
is there an arrow on each cam gear?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by InvaderTrax »</TD></TR><TR><TD CLASS="quote">Both keyways should be pointing up</TD></TR></TABLE>
wouldnt happen to have any pics would you? the motor is at my grandfathers house in the garage, while Im at home and cant work on it right now.
EDIT: and I didnt put on the cam gears, they were alrady on the cams when I bought the motor.
In the very center is where the gear slides over the cam. The indention is where the key goes. If your engine doesn't have a timing belt, you need to rotate the cams so that the key on each cam is pointing up, then rotate the bottom end so that #1 cylinder is at TDC (there's a mark on the flywheel indicating where #1 TDC is)
wow...thank you so so so much! I am finishing my swap on friday and need to get this bitch together. Umm...one last question, how hard is it to turn the cams with a socket?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by InvaderTrax »</TD></TR><TR><TD CLASS="quote">Fairly easy to turn then just by grabbing the gear with your hand and twisting. The bottom end takes a good size wrench</TD></TR></TABLE>
I was thinking that I needed to use a wrench for the cams, i know u have to use a wrench for the crank...that **** is tough to move...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egcoupe94 »</TD></TR><TR><TD CLASS="quote">
I was thinking that I needed to use a wrench for the cams, i know u have to use a wrench for the crank...that **** is tough to move...</TD></TR></TABLE>
not for me...
lol
not for me...
lol
JerseySiPOS
21
Jan 18, 2006 03:04 PM
