wont start?!?
Old May 30, 2006 | 12:51 PM
kittieeve's Avatar
Default wont start?!?
Hello
I have a delema. My 94 civic wont start when it is wet or humid outside. The fuel pump wont turn on. I spoke to a dealership and he had no clue except that it might be the main relay.
I had the same problem with my 91 a couple years ago.
Has anyone had this problem?
fixes?
Thanks
Old May 30, 2006 | 02:44 PM
JDM-EJ1's Avatar
Default Re: wont start?!? (kittieeve)
Same problem with my brothers DA. It would sometimes refuse to start when it was warm out. We replaced his main relay and haven't had problems since.
Old May 30, 2006 | 03:26 PM
kittieeve's Avatar
Default Re: wont start?!? (JDM-EJ1)
Thank you,
i will replace it and see if that helps
Old May 30, 2006 | 03:46 PM
JDM-EJ1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kittieeve &raquo;</TD></TR><TR><TD CLASS="quote">Thank you,
i will replace it and see if that helps</TD></TR></TABLE>
I know it has something to do the solders on the main relay going bad. And when metal gets warm, it expands. In theory causing the solders to become weak over time.
Old May 30, 2006 | 04:06 PM
Slamaccord's Avatar
I think their is thread out there on a F.I.Y. main relay.
Old May 30, 2006 | 04:12 PM
JDM-EJ1's Avatar
Default Re: wont start?!? (Slamaccord)
Main Relays are prone to go out on older Hondas.
Old Jun 1, 2006 | 02:31 PM
kittieeve's Avatar
Well
I changed the main relay and it is still doing it. Could it be a bad ground or wire?
collkid
13
Sep 16, 2015 09:10 PM
trevorjohn88ef
Nov 12, 2010 01:35 AM
90jdmcrxdude
Aug 5, 2006 07:34 AM
rleonekc
Jul 21, 2006 10:33 PM
the_rail
Jul 29, 2004 09:29 AM
