What header will be a direct bolt on for a B16 swap
Old May 30, 2006 | 12:23 PM
6speedMaster's Avatar
Default What header will be a direct bolt on for a B16 swap
What header will be a direct bolt-on for a B16a swap? Also will USDM syncros work in the YS1 tranny for 3rd and 4th gear?
Old May 30, 2006 | 12:24 PM
db8gsr_teg's Avatar
Default Re: What header will be a direct bolt on for a B16 swap (6speedMaster)
any b series header will fit
Old May 30, 2006 | 12:28 PM
vlc92189's Avatar
i have a b series dc sports.. it hs rust on it.. 85 shipped.!
SkoundrelUSA's Avatar
cute little bastard
Default Re: What header will be a direct bolt on for a B16 swap (db8gsr_teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by db8gsr_teg &raquo;</TD></TR><TR><TD CLASS="quote">any b series header will fit</TD></TR></TABLE>
For the most part, yeah. But you better make sure the collector size matches each other
Old May 30, 2006 | 12:34 PM
Default Re: What header will be a direct bolt on for a B16 swap (SkoundrelUSA)
Yeah that is the part I am worried about. Also can I run a test pipe with no CEL issues?
Old May 30, 2006 | 12:37 PM
SovXietday's Avatar
Only if you're OBD1
Old May 30, 2006 | 12:54 PM
Default Re: What header will be a direct bolt on for a B16 swap (SovXietday)
What headers show the best power gains on the B16. I havent owned a B16 since 1999 so it has been a while. I am looking to spend around $500 - $700
Old May 30, 2006 | 02:19 PM
kiddcarbuff's Avatar
500-700 eh??? get a toda for the bling factor or get a dc and use the rest of the $$ for something else
Old May 30, 2006 | 02:44 PM
cute little bastard
get a profab, hytech, sparks, or JDM ITR 4-1
Old May 30, 2006 | 02:46 PM
spoonracer84eg's Avatar
Im runng a dc sport header with skunk 2 test pipe and skunk 2 catback. Sounds awesome
Old May 30, 2006 | 03:50 PM
Default Re: What header will be a direct bolt on for a B16 swap (spoonracer84eg)
Are all the power gains about the same???
AtomicEG
Mar 10, 2008 04:20 PM
EJsKaTee1
Aug 21, 2007 03:46 PM
Nuke209
Dec 13, 2005 08:11 AM
VTECVillain
May 1, 2002 07:44 PM
