Inside integra help please....???? (Remove couple of compartment)
can anyone show me how to remove the stuff inside so I can paint the inside of my car...........I try to remove a couple of stuff...but like the center piece where the a/c control and the far left where the sun roof control........i'm hestitate about removing those...because when i try to i hear some kind of weird sound..it sound like something is cracking.....so I was trying to ask for some kind of step on how to remove those things............thx
Hey whats up man...I just took out the interior and strippied everything from seats to stuff inside my trunk...When you are taking out the whole dash...you need to take out everything else...vents just come out easily...as for the AC control unit...it should come out with the dash...just makesure its disconnected...and also check everything else in the connections...there is always somethin there to prevent me from removing it...also...you HAVE to take out the steering wheel...becareful with the airbag...make sure you disconnect it right and have the battery disconnected...for the steering wheel...you need to take out to star screws on the side of them...I hope that helped you out...i should be done with my interior soon...give me a email if you have any other questions because i went through the same thing...cyrusakakumar@gmail.com
also...you have to take out the whole center console first if you havent done that.
hope that helps
hope that helps
are you referring to a DC? if so, here are some links:
passenger airbag
http://www.team-integra.net/se...=1125
rear "triangle"
http://www.team-integra.net/se...=1127
climate control
http://www.team-integra.net/se...D=586
door panel
http://www.team-integra.net/se...D=591
dash
https://honda-tech.com/zerothread?id=954173
passenger airbag
rear "triangle"
climate control
door panel
dash
aesthetics82
34
May 10, 2004 07:52 PM
EKtypeRhaTcH
Jul 8, 2003 10:55 AM
