95 civic dx SRS light stays on
Anyway to get the SRS light to go out? Bought the car about a year ago and it's been on ever since. I know of another guy at work with the same car with the same exact problem. Anyone know what the problem would be or how to fix it?
Later
Kirk
Later
Kirk
well check if your airbag is busted if not then there a yellow plug under your dash, its a main reset botten switch you have tap that and the srs would flash and stay and once you do tap it again it should trun off just like how you would check the "check engine light" but first you have to know if your airbag works or not
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek_99_SiR »</TD></TR><TR><TD CLASS="quote">take the bulb out. end of story</TD></TR></TABLE>
Yeah that it
What's next remove the bulb for the oil pressure also. Some of us lke to fix our cars right the first time.
Yeah that it
i'm not being a smart *** or anything, but i had or you could say i still have the same problem on my 96 dx coupe. mine was one because one of the air bag sensor was messed up or something, the air bags didn't work after that anyways. so what i did was take the stock gauges out and just remove the plug for it that plugs in to the back of the stock gauges for your srs light. that's what i did and that made it stopped. i got tole it would cost way more thatn it's worth or needed to fix the sensor. beside i am going to take the air bag on the passenger side and i am changing my steering wheel. just thought i would offer my advice....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by packthis »</TD></TR><TR><TD CLASS="quote">
Yeah that it
What's next remove the bulb for the oil pressure also. Some of us lke to fix our cars right the first time. </TD></TR></TABLE>haha....
Yeah that it
jdmrida
Nov 21, 2008 08:58 AM
