91 crx si intake manifold on a 00 y8 block?
Old May 30, 2006 | 09:52 AM
GiMpInThaCiv's Avatar
Default 91 crx si intake manifold on a 00 y8 block?
So will a 91 crx si intake manifold work on a 00 y8 block? with obdiia?
Old May 30, 2006 | 09:56 AM
FalkenSiR's Avatar
Default Re: 91 crx si intake manifold on a 00 y8 block? (GiMpInThaCiv)
Yes, it will fit, but you will have some issues with sensors.
Old May 30, 2006 | 10:27 AM
Which ones are different?
Old May 30, 2006 | 10:30 AM
FalkenSiR's Avatar
Default Re: (GiMpInThaCiv)
Well, the map sensor is firewall mounted, the iat is not on the intake arm, but on intake manifold runner no 3 (or 4), the si mani don't think had an FITV either. Vaccum line routing is going to be a bitch also.
Old May 30, 2006 | 10:40 AM
aight bro thanks for the info.
Old May 30, 2006 | 10:42 AM
pdiggitydogg's Avatar
FITV and MAP are both on the TB, not the IM
(the y8 doesnt use a fitv anyway)
Youd be much better off, performance and simplicity, using a y8 manifold
SPIKE'S91CIVICSI
Feb 22, 2009 10:28 AM
JDMKid71
10
Dec 12, 2005 07:14 PM
JohnnyB70
Aug 24, 2004 06:38 PM
Dano
Sep 11, 2002 06:44 AM
