How do you replace drive belts on DX?
Old May 30, 2006 | 08:57 AM
nk2k2's Avatar
Default How do you replace drive belts on DX?
I wanted to replace the p/s and alternator belt on my LX. It has the d15b2 in it and im not sure exactly how to take it off and where the tensoners locations are. I looked through the FAQs and didnt see any write-ups for it. If you have any links for a write-up it would be greaty appreciated. Thanks.
Old May 30, 2006 | 11:29 AM
Redline130's Avatar
Default Re: How do you replace drive belts on DX? (4g4d)
Get a factory manual, it's the best money you can ever spend on your car.
http://www.helminc.com
Old May 30, 2006 | 04:32 PM
nk2k2's Avatar
Default Re: How do you replace drive belts on DX? (Redline130)
anyone else wanna help me out. i have to get this done tomm. i've already used alldata but no help from them.
Old May 30, 2006 | 05:10 PM
Redline130's Avatar
Alternator belt can be removed by loosening the top bolt on the upper bracket that it is bolted too. To tighten the belt, just use a pry bar or a long screwdriver and pull the alternator towards the firewall. Hold it with the prybar or screwdriver and tighten the same bolt you loosened to remove the belt. It should be a 12mm. You may have to loosen the 14mm bolt on the bottom of the alternator as well. As for the P/S, there should be a tensioner located on the top of the mounting bracket. Not sure what size it is 10mm? 12mm?
Old May 30, 2006 | 05:14 PM
Toshi's Avatar
it's 12mm and it's a bit difficult to get there, cuz it's between the main belt
Old May 30, 2006 | 06:31 PM
Tippyman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4g4d &raquo;</TD></TR><TR><TD CLASS="quote">I wanted to replace the p/s and alternator belt on my LX. </TD></TR></TABLE>
What's Power Steering?
Old May 31, 2006 | 11:38 AM
nk2k2's Avatar
Default Re: How do you replace drive belts on DX? (Tippyman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tippyman &raquo;</TD></TR><TR><TD CLASS="quote">What's Power Steering? </TD></TR></TABLE>
its some JDM underground ****...shhh
chinesebwoy
Honda Civic (2001 - 2005)
Apr 17, 2009 01:47 AM
nemesiskrp
Apr 14, 2009 10:10 PM
integracing86
Oct 26, 2006 01:52 PM
RedRex8
Sep 30, 2003 11:55 AM
B2FiNiTY
14
Sep 24, 2003 01:17 PM
