2000 CVR rear suspension noise
Trying to figure out what might be the problem with this car.
Its a 2000 CRV and anytime you make a hard U turn you can hear a "rubbing" noise from the rear. What could this be? Could it be the rear drum brakes that are causing this noise?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MooGoCow3 »</TD></TR><TR><TD CLASS="quote">If you would ave searched around a little you would have easily found the awnser.
You need to change the Dual pump fluid in your rear differential.</TD></TR></TABLE>
Thanks
I tried searching but came up with nothing, and most post I found about changing fluid in the rear diff applied to the S2000.
Thanks
