B18B Throttle Body, is it can fit to B16A IM?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prestidge81 »</TD></TR><TR><TD CLASS="quote">just want to confirm. is it can be fit to B16A IM?...and how big is the Inner dia.?</TD></TR></TABLE>
Yes. (sizes below)
b18a 58
b18b 60
b16a SiR 58
b16a Sir2 / b16a2 60
b16a3 58
If you want to upgrade find an ITR TB, they are 62.. but make sure the IM is portmatched to the TB when you go bigger.
Yes. (sizes below)
b18a 58
b18b 60
b16a SiR 58
b16a3 58
straight boring or tapered? i have tapered a b18 to 65mm and a jdm b16a to 68mm but it does take alot of time to thin out the walls... i normally dremmel grind the TB with 60grit bands, then 120grit bands, then use a abrasive buff 220grit and then 320 grit and it comes out really nice.. its about 20 dollars in materials and like 3-5 hours to do it
91_civicsi
Jun 15, 2004 04:59 PM
