GSR Throttle bracket and skunk2 intake manifold
Old May 30, 2006 | 06:57 AM
loud3nergy's Avatar
Default GSR Throttle bracket and skunk2 intake manifold
I have a skunk2 intake manifold on my b18c1 with the stock GSR throttle body. Is there anyway to flip the throttle body rotor to eliminate the need for a cable bracket?
Thanks in advnace!
Old May 30, 2006 | 07:22 AM
civicseth's Avatar
Bump for some help.
Old May 30, 2006 | 08:44 AM
Out of every
Default Re: GSR Throttle bracket and skunk2 intake manifold (loud3nergy)
im not sure if you have to do this, but this is what i did for my blox and it looks clean. your going to have to get a non gsr throttle pulley, itr throttle cable bracket and itr throttle cable . if i were you i would get a 92-95 throttle pulley . its what i used for my blox and its perfect
Old May 30, 2006 | 10:47 AM
loud3nergy's Avatar
awesome, any photos of said set up?
Old May 30, 2006 | 11:36 AM
mike1114's Avatar
Default Re: (loud3nergy)
Just get the GSR bracket.
Old May 31, 2006 | 09:19 AM
loud3nergy's Avatar
wont the bracket/cable hit the hood when closed with a skunk2 manifold in an EG hatch?
Old May 31, 2006 | 09:25 AM
Slamaccord's Avatar
Default Re: GSR Throttle bracket and skunk2 intake manifold (e gee two)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by e gee two &raquo;</TD></TR><TR><TD CLASS="quote"> . if i were you i would get a 92-95 throttle pulley . its what i used for my blox and its perfect </TD></TR></TABLE>
I never knew that they were interchangable.
HMMMMM Learn something new everyday.
Old May 31, 2006 | 09:30 AM
JeffBro's Avatar
Ok heres what I did. I took apart the throttle body and put a non-gsr throttle hat on and it works but it kinda turns out getto. Anytime you mess with the throttle body technically it needs to be recalibrated cause the throttle plate wont close perfict(either stick or not close enough). Now I am prob gonna end up getting an ITR throttle body anyways but you could also use a b16 one too its the same size as a gsr, long as its not for an older b16.
Old May 31, 2006 | 09:32 AM
Slamaccord's Avatar
Default Re: GSR Throttle bracket and skunk2 intake manifold (JeffBro)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JeffBro &raquo;</TD></TR><TR><TD CLASS="quote">Ok heres what I did. I took apart the throttle body and put a non-gsr throttle hat on and it works but it kinda turns out getto. Anytime you mess with the throttle body technically it needs to be recalibrated cause the throttle plate wont close perfict(either stick or not close enough). .</TD></TR></TABLE>
That can't be good. So its not a good idea to swap pullies ?
Old May 31, 2006 | 11:08 AM
loud3nergy's Avatar
I wouldn't think it would be anything major. I have already taken the throttle Rotor (what the cable attaches to) off of mine before with no changes. You might have to adjust the set screw because of some differences between the two rotors but its not like you are completely disassembling the throttle body..
PS. anyone have any photos using either the ITR parts or the GSR Throttle cable bracket?
Old May 31, 2006 | 12:59 PM
mike1114's Avatar
I have an EG with B series motor, skunk2 intake mani.
The OEM GSR bracket does not hit the hood at all.
You can get the bracket for an ITR and use it with the GSR throttle body.
Old May 31, 2006 | 10:57 PM
Out of every
Default Re: (mike1114)
okay... when i put mine back together everything was fine never had to adjust anything.
gsr with blox manifold with itr throttle cable and bracket w/ 92-95 civic pulley
the best pic i have... right now. dont have my digi cam
this pic was off a diy. which i got and it worked with no problems on mine
good luck
Old May 31, 2006 | 10:59 PM
ekb16's Avatar
http://technet.ff-squad.com/how-to/sk2im/
Old May 31, 2006 | 11:49 PM
Spracer03's Avatar
is that motor shot with the itr 4-1 header with a heatshield?
Out of every
Default Re: (Spracer03)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spracer03 &raquo;</TD></TR><TR><TD CLASS="quote">is that motor shot with the itr 4-1 header with a heatshield?</TD></TR></TABLE>
yes
Old May 31, 2006 | 11:52 PM
Spracer03's Avatar
can u tell its a header alot from the side? have cops ever f'd with you about it?? im considering one of these i wanna know if caops will take the "its a stock part" story
Old May 31, 2006 | 11:58 PM
Out of every
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spracer03 &raquo;</TD></TR><TR><TD CLASS="quote">can u tell its a header alot from the side? have cops ever f'd with you about it?? im considering one of these i wanna know if caops will take the "its a stock part" story</TD></TR></TABLE>
well i highly doubt they would even question it. they'll see the heat shield and think its stock. i doubt a cop would know anything about that header or the shield. no cops have ever popped my hood or messed with me.*knocks on wood*
Old Jun 1, 2006 | 08:29 AM
loud3nergy's Avatar
alright! Thanks guys! Thats the answer i am looking for!
Old Jun 1, 2006 | 09:18 AM
EK79's Avatar
Default Re: (e gee two)
SUPER CLEAN ENGINE <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by e gee two &raquo;</TD></TR><TR><TD CLASS="quote">okay... when i put mine back together everything was fine never had to adjust anything.
good luck</TD></TR></TABLE>
Drzhope89
May 17, 2017 12:09 PM
EG6Marcus
Feb 15, 2011 03:54 PM
existanzcivicb20
Mar 30, 2006 03:40 AM
ddong2lee
Feb 20, 2004 07:06 AM
1.8T_EG
Jul 13, 2003 07:42 PM
