Neeed help with ZC motor and Hf Tranny
I have an rebuilt DOHC zc motor and I am useing my hf tranny with it. I wanted to know if I would be able to use this set up? Someone had told me that I would burn my clutch up from the inside useing the hf tranny. Any input on this would really help. Thanks
this should work just fine. as long as you ahve the dohc zc from the civic and not the integra then you should be fine. the tranny should just bolt right up, I've used a std four speed, an si, and a dx tranny. hf should have no problem considering I think it's the exact same as a dx tranny, and they all use the same casings.
