After long run NO-TO-HARD start (please advise)
Hi all!
I did the engine swap not long ago. It runs good, however, after a prolonged run/use if I shut the engine off I will get hard time starting it again. Sometimes it will fire right up but if I loose the crank it will refuse to start. I have to wait a minute or so. After that it will fire like nothing happened!
Please advise, I don't want start throwing parts at it.
I've done preliminary tests, all seem to be ok. Fuel pressure ok, regulator ok, Injectors seem to be good, timing/ignition are dead-on.
I have a Main ECU (PMG-FI) relay as suspect. It feels as if it doesn't prime (fuel bleeds off) after long run!
Thank you!
Thank you!
95excoupe
17
Jun 17, 2007 03:47 AM
