primary oxygen sensor, where does it connect to?
Old May 29, 2006 | 11:34 PM
SneezR's Avatar
Default primary oxygen sensor, where does it connect to?
I am finally putting things back together after I had the motor pulled out.
For the life of me I cannot find the connector that connects the primary o2 sensor...
can anyone point me in the right direction? I tried looking through the helms but it doesn't show any specifics.
Couple pix
http://img142.imageshack.us/my...f.jpg
http://img142.imageshack.us/my...v.jpg
Modified by SneezR at 4:09 PM 6/2/2006
Modified by SneezR at 4:10 PM 6/2/2006
Old May 30, 2006 | 03:48 AM
blkb18's Avatar
Default Re: primary oxygen sensor, where does it connect to? (SneezR)
its near the header bracket on the backside of the block
Old May 30, 2006 | 08:19 PM
SneezR's Avatar
tried searching from underneath the car and from above. Still cannot locate the other end. I don't see any vacant connectors for that matter.
Does anyone have a pic laying around that might shed some light on the location.
Old May 30, 2006 | 10:26 PM
acurarock17's Avatar
what year car?
Old May 31, 2006 | 07:09 AM
SneezR's Avatar
sorry its a 1998 GSR
Old May 31, 2006 | 07:17 AM
Lan's Avatar
Lan
Default Re: (SneezR)
I am almost POSITIVE that the primary O2 sensor connector is above the cat INSIDE the floorpan. There should be a rubber grommit that you need to pull out to access it.
Old May 31, 2006 | 09:40 AM
SneezR's Avatar
I think you may be referring to the secondary o2 sensor which plugs into the cat converter.
Old May 31, 2006 | 09:49 AM
Lan's Avatar
Lan
OBD2B has both plugs in the cat on the teg
Old May 31, 2006 | 10:48 AM
SneezR's Avatar
you have pm
Old May 31, 2006 | 10:53 AM
Lan's Avatar
Lan
Replied
Old Jun 3, 2006 | 09:34 AM
SneezR's Avatar
pictures added. I still haven't figured it out
Old Jun 3, 2006 | 09:50 AM
Dartanian's Avatar
Default Re: (Lan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lan &raquo;</TD></TR><TR><TD CLASS="quote">OBD2B has both plugs in the cat on the teg </TD></TR></TABLE>
94-01 LS and 00-01 GSR have one in the collector, one in the back of the cat.
94-99 GSR have them both in the cat.
And the SECONDARY O2 sensor harness would be under the floor pan. The primary O2 sensor would be coming from the main harness behind the block somewhere.
civicboy420
25
Nov 14, 2015 07:11 PM
vtec2nv
Apr 12, 2013 04:52 AM
Whatislove
Honda Civic (2001 - 2005)
Dec 23, 2008 02:20 PM
Amused
May 9, 2006 06:59 AM
Jebus
Mar 21, 2003 02:43 PM
