Help! I am throwing a codes 3(MAP Sensor) and 6(Coolant Temp)
Old May 29, 2006 | 10:46 PM
SiHatchTurbo's Avatar
Default Help! I am throwing a codes 3(MAP Sensor) and 6(Coolant Temp)
It's not an integra but someone might have had this problem. I put a stock obd1 1.5 sohc motor in my 96 del sol. using a obd2 engine wiring harness and dizzy. and using a odb1 ecu with a clip converter. I have been trouble shooting and asking people what this problem could be but haven't got a solution. so if anyone could help that would be great.
Old May 30, 2006 | 05:29 PM
problem solved. loose wire on the A clip on the clip converter
silversoler
11
Oct 22, 2019 09:30 AM
SiHatchTurbo
May 30, 2006 05:30 PM
SiHatchTurbo
May 30, 2006 05:29 PM
civicobd1toobd2
May 10, 2006 02:52 PM
imlachg1
May 6, 2004 09:57 AM
