Does anyone have an opinion or review of this ebay catalytic converter???
http://cgi.ebay.com/ebaymotors...QrdZ1
I live in New Hampshire and there is no emission testing for I believe 1995 and below so the only reason I wouldn't purchase is if it would hurt performance lack of back pressure or somthing to that effect.Would this hurt my car,I realize the cats main reason for existence is emissions but I also know it helps with back pressure for something also.......anyone??? I know it's cheap,piece of **** but it is stainless and with no emissions,well you know.Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.speaker »</TD></TR><TR><TD CLASS="quote">thats not a cat..its basically a resonated testpipe ,,a straight through resonator..</TD></TR></TABLE>
So then you have one and will give us your opinion on how it works???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Screaming »</TD></TR><TR><TD CLASS="quote">
So then you have one and will give us your opinion on how it works???</TD></TR></TABLE>
i had one on my old lsvtec crx..but back when i bought it off ebay it was called a "testpipe" ,,but all the sudden its called high flow cat..like i said though its not a cat,,its just a resonated test pipe..its good quality if thats what you're asking,,its not just some piece of **** that falls apart in 2 weeks..
a regular test pipe will be annoying and loud, but a resonated test pipe will give you a different sound, it depends tho on if your exhaust is already resonated and if your muffler is straight threw or chambered.
i had a 2.25" tubing, 22" resonator, and chambered muffler with resonated tip so it was as queit as stock (under 5200revs atleast)..
the sound depends on everything else ,,engine,header,exhaust tubing diameter and wall size,muffler,etc,etc//
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FastReligion »</TD></TR><TR><TD CLASS="quote">it's alot better than your stock one if your asking for performance, I have one and it makes a good difference..</TD></TR></TABLE>
same here
same here
That's not even a cat..
i have this "cat" on my b18a hatch. where i live we don't have emmision testing but all the emission components have to be visually in place. it looks like a cat enough cuz i just passed inspection with it on. thats the only reason i put it on. did improve sound a tad over a staight "test pipe".
mrlegoman
Welding / Fabrication
10
Dec 1, 2006 07:08 PM
lowRIDAH
Sep 1, 2005 11:08 AM
