easy question
Old May 29, 2006 | 10:24 PM
GsrTurboCRX88's Avatar
Default easy question
Hey i just swaped in a lsvtec in my crx. I dont have an ecu but with my stock ecu would it crank over at all? I was just wondering cause i tried it to see if it would try to start but nothing happend but the ceck engine light just clicked on and off really fast
Old May 29, 2006 | 10:46 PM
thevtecnician's Avatar
Default Re: easy question (GsrTurboCRX88)
What ecu is it?
Old May 29, 2006 | 10:48 PM
Default Re: easy question (thevtecnician)
On my 88 crx si with b18b1 and jdm b16a head with ctr pistons(r.i.p.) It was obd0 and the ef8 sir ecu worked great.
Old May 29, 2006 | 11:15 PM
Suck my DX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thevtecnician &raquo;</TD></TR><TR><TD CLASS="quote">On my 88 crx si with b18b1 and jdm b16a head with ctr pistons(r.i.p.) It was obd0 and the ef8 sir ecu worked great.</TD></TR></TABLE>
bad idea...a stock pr3 will not perform well at all on that set-up...i can just imagine why its r.i.p
Old May 30, 2006 | 10:04 AM
Default Re: easy question (Suck my DX)
it is the stock crx si ecu not jdm
Old May 30, 2006 | 10:06 AM
jedubz's Avatar
Yes with any working OBD-0 ECU hooked up correctly (your engine is OBD-0 I'm assuming) it should crank over and idle but I don't recommend letting it stay on for very long.
Old Jun 12, 2006 | 01:08 PM
Default Re: (jedubz)
why? what would be the problem? Could I use an OBD 0 ls ecu?
Old Jun 12, 2006 | 01:13 PM
crxnj's Avatar
Default Re: (GsrTurboCRX88)
yeah the stock pm6 ecu will run the motor..i had a stock pm6 running my b16a for 2 weeks until my chipping kit came in..dont gun it though,,because the pm6 will run the 1.8 dohc engine lean..
apbtwhiskey
Apr 5, 2013 08:44 PM
cal_gecko
12
Apr 29, 2006 03:31 AM
mugenracer
Mar 13, 2005 09:37 AM
riceball777
Jun 1, 2003 01:17 AM
GeeSeeR
Sep 18, 2001 06:30 PM
