compression results
Old May 29, 2006 | 09:49 PM
floatfisher's Avatar
Default compression results
I was doing a little reading and came across that B18C5 motors should have a compression of 200psi. A few weeks ago I had a compression test done at the dealer and it was pretty much 175psi across all 4 cylinders. The mechanic said it was good "healthy motor". However, I called another dealer and they said that those numbers are not good and there not bad. The guy at the dealer did not know the min and max for compression numbers. So does anyone here know what the minimum psi reading a B18C5 motor can have??? If these numbers are too low im gonna take it in because I still have warranty until next March.
I should include that the leak down test was ok
any help would be appreciated
thanks
Old May 29, 2006 | 10:31 PM
itr1244's Avatar
Default Re: compression results (floatfisher)
if all 4 cyl 's number is somewhat close. it should be ok
Old May 30, 2006 | 09:45 AM
dc2r01's Avatar
ITRS should get 220-230psi + its a high compression motor..
Mine was a solid 220psi across 4 after my new shortblock and machined head...
Warranty??? gooodluck!
Old May 30, 2006 | 11:12 AM
anyone else with suggestions???
Old May 30, 2006 | 11:17 AM
fastvtecCL's Avatar
Default Re: (floatfisher)
ITR's should be around 220-240 comp...
dc2r01's Avatar
did u buy that yellow one from sic1 or whatever his name is??
hahaha,maybe you shoulda bought the mechanically perfec cw itr, with a little surface rust on the rear A emblem from someone tryn to steal it...that came off with some scrubbing and a new A emblem.., and needed a $100 A\C compressor.
Bahahhahaaha
$3500 my ***...when i read your PM it made me fall off my chair laughing.
New Kumho Ecsta tires=400
A\C pump =100
Emblem = $40
Recaro seats -700
=1240$
Modified by dc2r01 at 12:40 PM 5/30/2006
Old May 30, 2006 | 11:35 AM
Kicker773's Avatar
Default Re: (fastvtecCL)
search.. topic has been covered there are many factors that can alter/get the right compression, including the brand/type of compression tester used.
Old May 30, 2006 | 11:38 AM
Jon D's Avatar
as long as the #s are consistent you are fine..... PERIOD!
Old May 30, 2006 | 11:53 AM
Dave_B's Avatar
Default Re: compression results (Jon D)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jon D &raquo;</TD></TR><TR><TD CLASS="quote">as long as the #s are consistent you are fine..... PERIOD!</TD></TR></TABLE>
What about 0-0-0-0?
But yes, it's been covered several times. I personally wouldn't worry if yours are all consistant like that.
Old May 30, 2006 | 03:32 PM
s2kdre's Avatar
Default Re: compression results (Dave_B)
damn my jdm r motor had 250 in all the cylinders,
Old May 30, 2006 | 06:16 PM
tegratuner's Avatar
Default Re: compression results (jdmhonda)
i have 190-190-190-190, dealership said thats really good, they showed the paper the mechanic actually wrote it all down on.
Old May 30, 2006 | 06:48 PM
92TypeR's Avatar
FSAE
That is exactly correct.
My Dad's old compression tester reads 195psi on all 4 cylinders, while my snap-on measures 255psi on all 4. This is on a 12.3:1cr motor.
It is all about the consistancy between cylinders.
Old May 30, 2006 | 09:29 PM
itr1244's Avatar
Default Re: (dc2r01)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc2r01 &raquo;</TD></TR><TR><TD CLASS="quote">did u buy that yellow one from sic1 or whatever his name is??
Bahahhahaaha
A\C pump =100
Emblem = $40
Recaro seats -700
=1240$
Modified by dc2r01 at 12:40 PM 5/30/2006</TD></TR></TABLE>
wth's going on here?
Old May 30, 2006 | 10:09 PM
dc2r01's Avatar
Haha nothing.. its an inside thing ;P
nevermind
Joe, did u buy SIK1s yellow itr?? Which one did u finally get.. post some pics!
Justin3's Avatar
Default Re: (itr1244)
Going by exactly what Honda says would be that a BRAND NEW b18c5 should have a optimum compression reading on a tester of 213. Keep in mind that is for a BRAND NEW motor, the minimum allowable before they would say you would need a rebuild/re-ring is 135. Pay attention to what everybody else has said because it's the variance you want to look at more than your actual numbers unless they are unusually low(read, below 135). Your max variance between cylinders would be 28, if you're seeing numbers greater than that something is possibly wrong with your engine. You should start looking into what might be going on.
On a side note, if you had a compression and a leak down test done and especially, the leakdown was ok. Why are you even hear asking a leak down is going to tell you a lot more than a compression tester would anyday(i.e. look at the variance you see between testers like the example above). Come on man use your head.
mikeivb
Nov 11, 2009 11:13 AM
efking1985
Jul 26, 2007 07:13 PM
sdinteg
Feb 1, 2005 07:52 PM
builtprelude
Jan 22, 2004 10:49 PM
sjracer
Jan 21, 2003 03:28 AM
