B18a install
Does anyone have a good wirte up for putting a Obd1 b18a in a 91 Crx Si? I haveing serious problems even though people say it so easy plz help. anything is better than nothing
It is easy here is a good write up for a B16 install, are you staying OBD0 or converting to OBD1? Just take your time
http://www.crxresource.org/mod...d=134
have you tried searching?
i can give you 1 link right off the back
https://honda-tech.com/zerothread?id=1193782
the b16 and ls are pretty much the same for swapping in, besides the ls has less wiring (no vtec)
lmao loserkidwac beat me to it, same freakin links
i have a feeling i got a obd1 casue the harness is a bitch to hook up everything i need help with the vacuum diagram for the hoses. thats it o and do you need a Egr vavle on the mani cause it is in the way over my fuel rail i know it allows the enigne to heat up but i seen some without one so i was wondering if it is possiable.
Yours has an EGR? I know 90-93 AUTO tegs have EGRs so mostlikely you have a motor from a auto you may need to get an differnt intake mani in that case, need someone to back that up though...Look for a online pdf manul to help with vac lines should be able to find one easily, check HMT hybrid section I think there ae a few listed there for JDM cars
The DX Rex
Dec 22, 2004 12:43 PM
