exhaust and intake gain.............
Old Apr 14, 2002 | 07:51 AM
BOO YEAH's Avatar
New User
From: Witty Comment....., Stunning Response...., Follow Up Gag.....
Default exhaust and intake gain.............
what kinda gain can you get from an exhaust and intake on a 97 lude????
I will go with the short ram aem, and probably an apexi N1, but if other exhaust are better and around the same price let me know.
Old Apr 14, 2002 | 08:39 AM
tec-9-7's Avatar
Default Re: exhaust and intake gain............. (BOO YEAH)
you will lose power with any kind of underhood intake - exhausts are all about the same - probably 3-5 hp.
Paul
Old Apr 14, 2002 | 09:29 AM
mattmw88's Avatar
Default Re: exhaust and intake gain............. (tec-9-7)
This is news to me. I understand that all if any gains will be minnimal, but how do you figure you will loose power? or do you mean you could loose some low end and gain some high end? If this is so I guess I'm a stunna cause I have a short ram right now and soon to be aem cai and if there is no potential gains then I guess I'm doing it for the sound/look.
Old Apr 14, 2002 | 09:41 AM
vpforeva's Avatar
New User
Default Re: exhaust and intake gain............. (mattmw88)
underhood intake aka short ram, sucks hot engine air in, hot air = loss of hp
Old Apr 14, 2002 | 09:42 AM
mattmw88's Avatar
Default Re: exhaust and intake gain............. (vpforeva)
I realize that, but my question is dealing w/ cai- so cai lose power? I thought they pushed out higher end...
Old Apr 14, 2002 | 11:29 AM
tec-9-7's Avatar
The original question was in regards a short ram intake, so my comment was restricted to those. In my experience, you will gain some HP from a CAI.
Paul
Old Apr 14, 2002 | 12:50 PM
laughinxxx's Avatar
New User
Matt there was a test done on shart ram intakes. They did lose hp. All of the dyno charts in magazines are done with the hoods open with air being blown over the intake filter. It's basically a totally unrealistic dyno. I'm putting my stock air box in and picking up a K&N until I have the spare cash for an AEM cai.
Old Apr 14, 2002 | 06:31 PM
BOO YEAH's Avatar
New User
Default Re: exhaust and intake gain............. (laughin2.2)
i have not looked under the hood of one (yet) but would the stock airbox not be more restricing then a exposed filter, hence a hp gain no matter what, unless hondas are freaks of natures and are the only engines that make more hp with less airflow and a more restricted intake.....
Old Apr 14, 2002 | 08:58 PM
laughinxxx's Avatar
New User
Stock air boxes at least suck up cold air from under the passenger side bumper. The hot air taken in by a short ram intake kills and power gained by a freer air path.
Old Apr 14, 2002 | 08:59 PM
Accord94DX's Avatar
stock air intakes are not shiny. Therefore stock air intakes =
Old Apr 14, 2002 | 09:13 PM
laughinxxx's Avatar
New User
Default Re: exhaust and intake gain............. (Accord94DX)
LMAO. Just triple chrome plate dat biatch.
Old Apr 15, 2002 | 03:24 AM
tec-9-7's Avatar
They are not freaks of nature, but they are high compression engines w/ rather cautious computers. If the computer senses the intake charge temperature climibing above ~120 it begins pulling timing, hence any gain in performance you may have gotten from better intake flow is erased, and more to boot, by the timing retard.
But hey, if you are really that sure, go ahead and ignore what I've told you. It's your money.
Paul
Old Apr 15, 2002 | 04:36 AM
prelude10's Avatar
This is crap, I have a short ram intake and i got a big difference in power. Night and day. So all of you guys dissing short ram kiss my ***,cause you probably never driven a car with a short ram, your just talking about what you heard from a friend with a ghetto home hade intake. Sorry for going on but it's tru.
Old Apr 15, 2002 | 06:38 AM
tec-9-7's Avatar
Default Re: exhaust and intake gain............. (prelude10)
OK smart-guy -
http://www.hondaprelude.com/resource...ermarket&id=29
and for your further enjoyment -
http://www.hondaprelude.com/resource...ermarket&id=28
So watch it when you start blowing smoke from your *******. I don't normally post things as fact that I don't have some direct knowledge of - on the occasions I do, I qualify them as such. I'm glad you are enjoying your short-ram. They sure do SOUND fast...
Paul
Old Apr 15, 2002 | 06:42 AM
Honda318dx's Avatar
Paul
Thats pretty much it, AEM CAI is the ONLY way to go
Old Apr 15, 2002 | 07:05 AM
Steppin Razor's Avatar
New User
Default Re: exhaust and intake gain............. (Honda318dx)
All you have to do is put a heat shield around a short ram. $10 worth of aluminum from Home Depot.
You most definitely would not lose power with a short ram. In fact, you'll gain throughout the rpm range, as opposed to the midrange hump of the cold air.
Old Apr 15, 2002 | 07:16 AM
tec-9-7's Avatar
Default Re: exhaust and intake gain............. (Steppin Razor)
I think some of that heavier foam-board insulation might be easier to cut/fit/seal - I'd also be a little concerned that aluminum might wear a hole in the intake tube over time from vibration - I would also be inclined to open the hole that the factory intake goes thru some more. Note tho that this is more than just sticking the intake on the car and assuming it will make some power. If you just stick the thing on the car, it will lose power from stock.
Paul
Old Apr 15, 2002 | 09:10 AM
prelude10's Avatar
Ok, you don't know how my car runs with it. I felt a big diffrence. I know for a fact that did not lose power. I gained. SO you can kiss my ***.
Old Apr 15, 2002 | 09:16 AM
tec-9-7's Avatar
Oh yeah - I'm sure we're all real impressed w/ you butt-dyno numbers - did you correct for conditions or is your gain uncorrected?
Man, as long as you're happy w/ your intake, more power to you - but in this case, you're factually incorrect.
Paul
floydkahue
Honda CR-V & Element
Nov 18, 2012 04:52 AM
ultimatecivictyper
Oct 28, 2006 08:21 PM
EG2Driver
Dec 30, 2005 09:13 PM
Syke Fu
Oct 24, 2004 01:18 PM
grngsr01
Feb 17, 2002 08:53 AM
