Ok so i bought a crx
Old May 29, 2006 | 07:04 PM
newman271's Avatar
Default Ok so i bought a crx
I bought a crx around the corner from my house and it idles at 2500 rpm. I was wondering where the idle control screw is and how much should i turn it? what happens is this when i first start it it'll idle perfect... as soon as i touch the gas it will jump up to 2500 rpm and idle there. also its a 89 crx si.. any help would be greatly appreciated.
Old May 29, 2006 | 07:07 PM
'90crxSI's Avatar
Default Re: Ok so i bought a crx (newman271)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by newman271 &raquo;</TD></TR><TR><TD CLASS="quote">I bought a crx around the corner from my house and it idles at 2500 rpm. I was wondering where the idle control screw is and how much should i turn it? what happens is this when i first start it it'll idle perfect... as soon as i touch the gas it will jump up to 2500 rpm and idle there. also its a 89 crx si.. any help would be greatly appreciated.</TD></TR></TABLE>
If it starts and runs perfect until you press the gas, then its not the idle...i bet the throttlebody needs a good cleaning, or your petal is sticking....or both. Clean the throttlebody out real good, make sure theres no gunk buildup on the outside where the mechanism that is controlled by the pedal, etc.
Old May 29, 2006 | 07:10 PM
Tippyman's Avatar
Default Re: Ok so i bought a crx (88crxSI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88crxSI &raquo;</TD></TR><TR><TD CLASS="quote">... or your petal is sticking....or both. </TD></TR></TABLE>
Mine does that sometimes. I put my foot under the pedal and lift the pedal up. It stops it. I'm just too lazy to find the source of it.
Old May 29, 2006 | 07:21 PM
'90crxSI's Avatar
Default Re: Ok so i bought a crx (Tippyman)
same here, but mine is only at like 1200 rpms...and thats not to bad...just pop it up with your foot and its back down to about 700 or so
Old May 29, 2006 | 07:28 PM
eda6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tippyman &raquo;</TD></TR><TR><TD CLASS="quote">
I'm just too lazy to find the source of it.</TD></TR></TABLE>
on the pedal end of the throttle cable there's a rubber bushing. I bet the cable is wearing a groove in the bushing and causing it to bind. it's an easy fix, you just have to feel around under the dash and pull up on the cable to remove it then go into the bay, twist and pull it out. it's a 10 min. job.
2ndgenaccord
Classic Hondas
Jan 20, 2013 12:57 PM
krysted9354
Classic Hondas
Jun 4, 2009 04:49 AM
redrexracer
Dec 22, 2006 08:38 AM
roterx7
Feb 20, 2006 07:41 PM
