Clutch for Jdm B16-Need part #
91 civic DX hatch with a JDM B16a, car was automatic bought a front clip from a RHD Integra ( 91 i think) converted to manual and used the clutch cable from the clip. Car was backed into at a redlight and the clutch cable broke-plus body damage. Can anyone tell me the correct cable to use? I have searched and tried the SI cable and others, but they are too short. Can anyone give me the part # for a cable that will work? I have tried all the suggestions that I found while searching , but none seem to work.
stock clutch cable works dont say it doesnt because i have on my b16 crx...but the 90-93 integra cables fits better and gives more adjustment..for part number i was looking here www.acuraoemparts.com and it appears to be 22910-SK7-A02
I have tried the cable from an88 CRX Si and it will not work. Is it shorter than a 91 Civic DX cable? I installed it by removing the bracket on the transmission and reinstalling it but car will not go into gear with engine running. Any ideas?
i got a 88 crx si and used stock clutch cable with the B16a swap with stock clutch..but when i put in my racing 6 puck clutch it wouldnt work so now i got 90-93 integra cable..
I have a dx cable and i cant get it to reach all the way and like you said it also wont go into gear... so is it not going into gear because of the cable and when im using a dx cable, should i use dx bracket or the b16 bracket also do i have to do any moving to the bracket?
Nutnwrench
Jun 18, 2008 08:55 PM
VTECVillain
May 12, 2002 04:39 PM
