Honda S2000 Honda S2000
Using harnesses with stock seats: safe?
Old May 29, 2006 | 05:16 PM
Panda-san's Avatar
Default Using harnesses with stock seats: safe?
Hello. First, I don't have an S2000, I have S2000 seats in my 2001 Prelude. I want to install harnesses, but I want to do it right. Autopower rollbar (or some other quality roll bar or harness bar), quality harnesses (takata?) and, if necessary, racing seats.
However, I like the S2000 seats I have, so I was curious, would it be safe to use harnesses with them? Would it be safe to, say, cut out the mesh and run harnesses through there?
I haven't purchased anything yet, so I'm still in the research stage and I want to keep this safe. So if running harnesses through the mesh is a bad idea, then I'd appreciate the heads up.
Thanks for any help.
Old May 29, 2006 | 05:23 PM
JDM knowledge's Avatar
Default Re: Using harnesses with stock seats: safe? (Panda-san)
i think if you run them through the mesh area they will be too high up or too close together and may harm you more than save you. More i think about it i havent had those seats in my S for awhile now so i really dont remember how high the back portion is.
Old May 29, 2006 | 05:32 PM
Miracle's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM knowledge &raquo;</TD></TR><TR><TD CLASS="quote">i think if you run them through the mesh area they will be too high up or too close together and may harm you more than save you. More i think about it i havent had those seats in my S for awhile now so i really dont remember how high the back portion is.</TD></TR></TABLE>
WoRd.
You know what youre talking about. The back portion, from what ive seen, would sit at the head, or base of the neck. Depending on the height of the driver.
Old May 29, 2006 | 05:40 PM
iam7head's Avatar
Default Re: Using harnesses with stock seats: safe? (Red7thGen_ex)
roll cage have no place for street car, with the harness(assuming you will have a harness bar fab'ed for it) and roll cage, you are risking your melon for not using a helmet.
You might can do away without a helmet if you have a proper sized sedan but for the S, there's no much head room to squeeze the tube in(without interferening/contacting with your melon in case of a crash)
&lt;--owner of a Snell/dot helmet and Sparco 4 point harness(hpde)
Old May 29, 2006 | 07:19 PM
Nishant's Avatar
Default Re: Using harnesses with stock seats: safe? (iam7head)
You should not use a harness with the S2000 seats. It will cause more harm in an accident. It is not safe!
Old May 31, 2006 | 03:42 PM
Panda-san's Avatar
Default Re: Using harnesses with stock seats: safe? (Nishant)
Thanks for the feedback everybody.
631 Teggy
Honda S2000
11
Jan 10, 2008 01:37 PM
hamadiscool
Aug 8, 2006 07:38 PM
hamadiscool
Honda S2000
Jul 31, 2006 05:30 PM
bcbrett
Feb 21, 2005 07:55 PM
ILOVEGIRLS
Feb 18, 2003 02:47 PM
