need crx help! ASAP! searched and tested!
ok, i have an 89 crx hf with a b18 swap. when i got the car it had a giant hole above the gastank and had to weld up the 7"x20" hole along with fixing the fuel pump harness. to fix the pump prob. i used a 92 gsr fuel pump and it worked for a while and then it just died and wont restart. i checked the main relay, power, ground to the pump which both are ok but the pump still wont kick on. i've bought 3 fuel pumps and the first two worked for about an hour and then they stopped working. any ideas of what might be wrong or something to test will be gtreatly appr.
thanks
J.D.
thanks
J.D.
check that main relay again!!! Look here, this is VERY useful!!!!
http://www.tegger.com/hondafaq/faq.html#startrun
i checked the main relay and it's good it's clicking and everything. i think i'll just rewire the whole fuel pump wireing from the main relay back. good idea or bad idea?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88crxSI »</TD></TR><TR><TD CLASS="quote">check that main relay again!!! Look here, this is VERY useful!!!!
dooooooooooooooodddd! excellent link bra! thanx.
</TD></TR></TABLE>dooooooooooooooodddd! excellent link bra! thanx.
does anyone have a wireing diagram for thr the main relay i need to which wires coming from the main relay go to the pump, and the page doesnt show that. any help is greatly appriated!
thanks J.D.
thanks J.D.
