97 LS stock cd player reset and locked
Old May 29, 2006 | 02:12 PM
MaTTxx's Avatar
Default 97 LS stock cd player reset and locked
I recently unhooked my battery to help jumpstart some jetskis and when i hooked the battery back up everything electronic reset including the stock cd player face. When i started the car the radio would not play.
Instead it asked for a password/pin that was 4 digits. I tried 3 times then it didn't ask anymore. Now it reads "error -4" and i cannot use it at all.
My plan is to unhook the battery again after i get the stock pin number for this thing. If there is anyone out there that has a solution to this simple problem, please help me.
Modified by MaTTxx at 4:24 PM 5/29/2006
Old May 29, 2006 | 03:37 PM
GranadaTeg's Avatar
Default Re: 97 LS stock cd player reset and locked (MaTTxx)
Disconnect the battery for like 3 mins.
Reconnect.
Make sure you are entering the correct code.
It should work now.
Old May 29, 2006 | 03:47 PM
.brian.'s Avatar
Default Re: 97 LS stock cd player reset and locked (Slo Cord)
if you do not have the code, you will have to get it from the dealer.
Old May 29, 2006 | 04:07 PM
98GSRrdr's Avatar
Default Re: 97 LS stock cd player reset and locked (.brian.)
I took my car to the dealership for somthing really e/z ... a 15 min fix .. anyways i go back jump in thank them and notice my cd player was locke ... they said np take 5 mins ...to get the code .. then said cuz i had the tapeplayer thats under the cd radio deck that they couldnt see a number ... or a code or somthing that gives them the pin# they pulled my headunit and then back to normal .. dunno how they get the pin# but they did take the headunit out for some reason...
yaga
Mar 27, 2007 11:37 AM
BURNdg
Feb 16, 2006 05:07 PM
Windows 95
Jan 6, 2003 03:23 PM
