Skunk Pro2 cams in 97 R, idle?
Old May 29, 2006 | 10:57 AM
Dat1BVtecN's Avatar
Default Skunk Pro2 cams in 97 R, idle?
My cousin has a 1997 R and just installed Skunk2 Pro2 cams but were having a really hard time trying to make it idle. It has a Apexi VAFC and is running the stock itr ecu. Anyone have any experince with the Skunk2 Pro2's to make it idle, and another question is should this ECU be able to handle these cams, any help would be appreciative
Old May 29, 2006 | 12:34 PM
UncleD's Avatar
Default Re: Skunk Pro2 cams in 97 R, idle? (Dat1BVtecN)
Pro2's in a stock motor running on a stock ecu? Why?
Old May 30, 2006 | 07:28 AM
Dat1BVtecN's Avatar
Default Re: Skunk Pro2 cams in 97 R, idle? (clean rice)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clean rice &raquo;</TD></TR><TR><TD CLASS="quote">Pro2's in a stock motor running on a stock ecu? Why?</TD></TR></TABLE>
its not a stock motor bro, block is bored/sleeved to 84.5mm, the only thing that is stock is basically the ECU.
Old May 30, 2006 | 10:41 AM
spoonek9's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dat1BVtecN &raquo;</TD></TR><TR><TD CLASS="quote">its not a stock motor bro, block is bored/sleeved to 84.5mm, the only thing that is stock is basically the ECU.</TD></TR></TABLE>
Even more of a reason not to run the stock ECU. Get it tuned!
Old May 30, 2006 | 12:02 PM
UncleD's Avatar
Default Re: Skunk Pro2 cams in 97 R, idle? (spoonek9)
Oh ok, gotchya.
Old May 30, 2006 | 10:21 PM
Dat1BVtecN's Avatar
im gonna try to advance the dist. tomorrow, and try advancin the cam gears also, any other ides how to make this bitch idle, it has an VAFC but i have no clue how to mess with that, what is "wide throttle" and "narrow throttle"?
Old May 30, 2006 | 10:42 PM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dat1BVtecN &raquo;</TD></TR><TR><TD CLASS="quote">im gonna try to advance the dist. tomorrow, and try advancin the cam gears also, any other ides how to make this bitch idle, it has an VAFC but i have no clue how to mess with that, what is "wide throttle" and "narrow throttle"?</TD></TR></TABLE>
DON'T TOUCH ANYTHING. You ******* with it is only going to make matters worse.
If the motor is built and bored and sleeved and etc, why the hell is he only using a VAFC? Get a Hondata, Crome or Uberdata and get it professionally tuned on a dyno.
Old Jun 1, 2006 | 09:40 PM
MJobe's Avatar
Default Re: Skunk Pro2 cams in 97 R, idle? (JDM_Ej)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Ej &raquo;</TD></TR><TR><TD CLASS="quote">
If the motor is built and bored and sleeved and etc, why the hell is he only using a VAFC? Get a Hondata, Crome or Uberdata and get it professionally tuned on a dyno.</TD></TR></TABLE>
forsure , i still cant believe your running a stock ecu
Old Jun 2, 2006 | 08:50 AM
trickeng's Avatar
Default Re: Skunk Pro2 cams in 97 R, idle? (NAalltheWay91)
to answer your question, those cams SHOULD purrrr at idle. even with the stock ecu and injectors.
but the big question is what else did you do while installing the cams??? did the afc go in at the same time? if so, take it out.
Old Jun 2, 2006 | 08:58 AM
MJobe's Avatar
Default Re: Skunk Pro2 cams in 97 R, idle? (trickeng)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trickeng &raquo;</TD></TR><TR><TD CLASS="quote">to answer your question, those cams SHOULD purrrr at idle. even with the stock ecu and injectors.
but the big question is what else did you do while installing the cams??? did the afc go in at the same time? if so, take it out. </TD></TR></TABLE>
Skunk 2 pro's have a lopey idle because of the Large primarys they have, even with good tuning with hondata or chrome etc. you will still have somewhat of that lopey idle.
Old Jun 2, 2006 | 09:36 AM
trickeng's Avatar
but the car should still idle and not stall out.
when he says pro i take that as pro-series which are available in different stages, and with stg 1-2 i've never had a lopey idle and with 3's its very little. ????
sounds like he has something else going on to me.
Old Jun 2, 2006 | 11:23 AM
MJobe's Avatar
sounds like he has something else going on to me.</TD></TR></TABLE>
your prolly right , do a compression test etc.
Old Jun 3, 2006 | 10:39 AM
Dat1BVtecN's Avatar
Mike thanks for the info that i already know about the new Pro series cams have larger primary lobes(mike you retard), the Apexi VAFC was already in the car, we put in a friends chipped P28 ECU and it helped a little, but still sometimes wanna die, we just need to take this thing to a dyno and tune it something better than VAFC, think Hondata or Crome. There is nothing wrong with the motor, its just the tuning that is needed for this bad boy to idle
Old Jun 4, 2006 | 08:25 PM
MJobe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dat1BVtecN &raquo;</TD></TR><TR><TD CLASS="quote"> we put in a friends chipped P28 ECU and it helped a little, but still sometimes wanna die</TD></TR></TABLE>
probably because the baseline on the ecu was not made for toni's set up how many times do i have to tell these ametures , one ecu DOESNT fit all
you NEED atleast a basemap with those cams for them to idle...SEARCH next time
Old Jun 4, 2006 | 09:18 PM
Combustion Contraption's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trickeng &raquo;</TD></TR><TR><TD CLASS="quote">to answer your question, those cams SHOULD purrrr at idle. even with the stock ecu and injectors. </TD></TR></TABLE>
Wrong. There is alot of overlap present on those cams causing a lack of vacuum in the manifold throwing off the MAP sensor reading.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trickeng &raquo;</TD></TR><TR><TD CLASS="quote">but the car should still idle and not stall out.
It SHOULD idle and stall out. Especially if you installed the cams 'straight up'. The Pro Series camshafts are very aggressive. Dont be fooled by the Stage #'s. That Stage 2 is not made to be a 'drop in' cam. Retard the intake cam 1-2 degree's and take away fuel at idle UNTIL you can get it to the dyno.
Old Jun 4, 2006 | 09:37 PM
Dat1BVtecN's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NAalltheWay91 &raquo;</TD></TR><TR><TD CLASS="quote">
you NEED atleast a basemap with those cams for them to idle...SEARCH next time </TD></TR></TABLE>
ametures?!? haha i think i taught you everything you know till this day, oh yea, you wanna run Toni now? didnt think so haha ****** wannabe
anyways, we finally got this bitch to idle like around 1300 rpm
Old Jun 5, 2006 | 06:29 AM
reddevil94's Avatar
Default Re: Skunk Pro2 cams in 97 R, idle? (Combustion Contraption)
good info....running into the same situation...but I am running Crane Stage 3 Cams..... the block is 81.50 and trying to make it idle.......
Old Jun 5, 2006 | 08:34 AM
MJobe's Avatar
actually,, YES I DO, im waiting on some parts
Old Jun 5, 2006 | 08:40 AM
Dat1BVtecN's Avatar
actually,, YES I DO, im waiting on some parts</TD></TR></TABLE>
haha waiting for the last year and a half i see, haha we done with racing with you man, NEXT
Old Jun 5, 2006 | 08:46 AM
MJobe's Avatar
well see
mike1jag
Oct 24, 2007 07:39 PM
b16a4
10
Jan 16, 2007 02:16 PM
b16a4
Jan 16, 2007 11:23 AM
^AnDre^
28
Sep 13, 2006 05:09 PM
