H22 tapping. cam scratched
Old May 29, 2006 | 08:59 AM
boostinh22
Guest
Posts: n/a
Default H22 tapping. cam scratched
motor specs:
h22a4
type s pistons
eagle rods
clevite main bearings
oem rod bearings
full ferrea valvetrain.
stock exhaust cam, type s intake cam
Last night i was driving down the highway and noticed the motor started tapping.
pulled off to see what it was and decided to check the oil. it was empty. the oil light hadn't come on at all. after adding oil, the noise isn't as bad. it's just a tapping coming from the head(i think)
when i checked the oil, it wasn't showing on the dipstick...i only added about 3 qts and now it's a bit over the top mark on the dipstick.
i pulled the valve cover off today and all of the exhaust rockers and cam lobes are scratched pretty bad. i checked the valve lash and it's still within spec.
the motor still runs strong, just like before, but won't idle. it stalls if you push in the clutch and let off the gas. could this just be because of the rocker/cam situation? or is something else probably messed up?
any ideas?
h22ej8
Jun 7, 2021 10:28 AM
mtdineen
17
Oct 30, 2014 06:23 PM
B18C-YA!
Jun 1, 2006 09:17 PM
hondatuner20
13
Mar 4, 2006 06:38 PM
user 98292739
Apr 2, 2005 02:42 PM
