Tire Picking help
Old May 29, 2006 | 06:18 AM
mushu315's Avatar
Default Tire Picking help
I need help picking out some tires.
if I want to get rims with
15x6.5 with 40 offset
what sizes will fit on these rims? I'd like to have it low profile, close to the Civic Si 99-00
tHanks
Old May 29, 2006 | 08:01 AM
SkoundrelUSA's Avatar
cute little bastard
Default Re: Tire Picking help (mushu315)
195/55/15
195/55/15
205/50/15
I think
Old May 29, 2006 | 08:34 AM
EG2Driver's Avatar
Default Re: Tire Picking help (SkoundrelUSA)
here is what 195/50/15 look like on 15x6.5 rims with +38 offset.
Old May 29, 2006 | 08:49 AM
ekcivic9's Avatar
195 looks perfect, it gives that nice meaty look without looking like a donut or too stretched. safer for curbing too
Old May 29, 2006 | 09:02 AM
EG2Driver's Avatar
Default Re: (ekcivic9)
the AVS 100 do have a lip saver or whatever its called. The tire actually comes out like 15 mm out to protect it from the curb, and they're cheap as hell! Mine were 70 bucks a pop.
Old May 29, 2006 | 12:12 PM
mushu315's Avatar
Default Re: (DeadEnd9009)
i'm just confused about the offset and the ratio?
because when i select my tires it'll say... 195/??/15
i think i understand the first and last number
but the middle... the some ratio... does that mean the... 15x 6.5? so do i select 65?
Old May 29, 2006 | 12:22 PM
bsixteen's Avatar
the middle number is basically the height of the sidewall of the tire..or the "thickness" from edge of rim to edge of tire 35 series tires will look like electrical tape wrapped around your wheel..and well..you can see what 50 series will look like from the pic above.
cute little bastard
Default Re: (mushu315)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mushu315 &raquo;</TD></TR><TR><TD CLASS="quote">i'm just confused about the offset and the ratio?
No. The "middle number" is the profile/series. Or the height of the tire.
the 6.5 means the width of the rim itself
Old May 29, 2006 | 12:25 PM
CAVTECSol's Avatar
here is the same rim with a 205/50/15
why not go to the 205 width and gain a little extra grip?
Old May 29, 2006 | 12:30 PM
Voyage34's Avatar
Default Re: (CAVTECSol)
the middle number is the height of the sidewall, but it is listed as a percent of the tread width. for example, 205/50/15 means the tread is 205mm wide, and the sidewall is 50% of that width, and it fits on a 15" rim.
Old May 29, 2006 | 12:50 PM
cambopheonix56's Avatar
Default Re: (Voyage34)
get 205/50/15
Old May 29, 2006 | 03:23 PM
viahiptop's Avatar
Default Re: (cambopheonix56)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cambopheonix56 &raquo;</TD></TR><TR><TD CLASS="quote">get 205/50/15 </TD></TR></TABLE>
Old May 29, 2006 | 03:30 PM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekcivic9 &raquo;</TD></TR><TR><TD CLASS="quote">195 looks perfect, it gives that nice meaty look without looking like a donut or too stretched. safer for curbing too </TD></TR></TABLE>
195s are meaty-looking? LoL . . . I guess my 225/45-15s are like steamrollers then.
Old May 29, 2006 | 03:31 PM
vwaddicct07's Avatar
138.89.183.231
Toyo Proxes 195/45/15
Old May 29, 2006 | 03:32 PM
bsixteen's Avatar
Default Re: (Targa250R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R &raquo;</TD></TR><TR><TD CLASS="quote">
195s are meaty-looking? LoL . . . I guess my 225/45-15s are like steamrollers then.</TD></TR></TABLE>
post a pic
Old May 29, 2006 | 03:34 PM
ekcivic9's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R &raquo;</TD></TR><TR><TD CLASS="quote">195s are meaty-looking? LoL . . . I guess my 225/45-15s are like steamrollers then.</TD></TR></TABLE>
more like a tube you go tubing on. i hate fat round tires
Old May 29, 2006 | 05:38 PM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekcivic9 &raquo;</TD></TR><TR><TD CLASS="quote">more like a tube you go tubing on. i hate fat round tires </TD></TR></TABLE>
It's not round when it's on a 7"+ wheel . . .
Old May 29, 2006 | 10:16 PM
beav's Avatar
you guys are all lost.
i feel like a retard for actually reading all the stuff you guys wrote, so let me clear this up.
the first number is the width of the tire. the second number is the hieght of the tire measured in percentage of the width. so for example a 195/50 tire...the height is 50% of its width. a 195/60 tire...the height is 60% of its width. get it? not that hard. offset has nothing to do with tires. offset has to do with how far the wheel protrudes from the hub. and finally...when you look at the width of you rim...for example 6.5 inches...you have to make sure with the company of the tire you choose... what size will be able to hold on what width. on most 15 inch wheels, a 205 tire is as wide as you can go. ive seen 215 but it depends on the make and model of tire.
Old May 29, 2006 | 10:26 PM
Dilly's Avatar
Default Re: (aallbbeerrtttttt)
while you guys argue with all this yes and no's. im gonna go ahead and just say 205/50/15. haha.
Old May 29, 2006 | 10:38 PM
EK79's Avatar
http://www.qzx.com/about/stuff/arguing.jpg
id post the picture but i dont know how too DUUHHHH
Old May 30, 2006 | 06:03 AM
Sleepy_Red_hatch's Avatar
Default Re: Tire Picking help (stoopid monkey)
195/50/15 FTW!! less rotational mass and almost the same thread patch
Old May 30, 2006 | 09:05 AM
Voyage34's Avatar
Default Re: Tire Picking help (Sleepy_Red_hatch)
for your car, (you mentioned 99-00 si so thats what im going off) came with (IIRC) 195/55/15 stock, moving down to a 195/50/15 will throw your speedometer and odometer off by 3.3%. the 195/50 is over 3/4" smaller diameter than the 195/55.
the smaller tires also mess with your final gearing too since mph/rpm functions off tire size as well sa transmission ratios
if you want a slightly wider tire then go 205/50/15, its only 1/3" smaller or 1.6%.
195/55/15 or 205/50/15 are your best options.
Modified by Voyage34 at 12:41 PM 5/30/2006
Old May 30, 2006 | 10:34 AM
94hatchling's Avatar
Default Re: Tire Picking help (Voyage34)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Voyage34 &raquo;</TD></TR><TR><TD CLASS="quote">195/55/15 or 205/50/15 are your best options.</TD></TR></TABLE>
x2
Old May 30, 2006 | 11:38 AM
DaveSi677's Avatar
Default Re: Tire Picking help (94hatchling)
ok first off this should be in the wheel and tire forum and not here.
second it depends for which car this tire is going on.
If it is going on a 92-95 civic then the correct size would be 195/50/15
if it is for a 99-00 civic Si then the correct size would be 195/55/15 or 205/50/15 but the 195/55/15 would be much better.
If you go to the tire forum there is Nsxtasy there and he could answer you question about tires and offsets much better then anybody here.
Dave
Old May 30, 2006 | 11:55 AM
bsixteen's Avatar
Default Re: (beav)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beav &raquo;</TD></TR><TR><TD CLASS="quote">you guys are all lost.
the first number is the width of the tire. the second number is the hieght of the tire measured in percentage of the width. so for example a 195/50 tire...the height is 50% of its width. a 195/60 tire...the height is 60% of its width. get it? not that hard. offset has nothing to do with tires. offset has to do with how far the wheel protrudes from the hub. and finally...when you look at the width of you rim...for example 6.5 inches...you have to make sure with the company of the tire you choose... what size will be able to hold on what width. on most 15 inch wheels, a 205 tire is as wide as you can go. ive seen 215 but it depends on the make and model of tire.</TD></TR></TABLE>
blah blah blah. everything you said was already posted above you so what are you trying to prove?
