What oil should i run?
Old May 29, 2006 | 05:47 AM
PWRDbyHseries's Avatar
Default What oil should i run?
i just bought a JDM H22 from Noyan USA and they told me that it has around 40k on it and i was just wondering what oil should i start out on. Mobile 1 Full Synthetic or Synthetic Blend or what?
Old May 29, 2006 | 05:52 AM
E-Money's Avatar
Default Re: What oil should i run? (PWRDbyHseries)
full synthetic 5w-30
Old May 29, 2006 | 06:25 AM
kornerk12's Avatar
Default Re: What oil should i run? (E-Money)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by E-Money &raquo;</TD></TR><TR><TD CLASS="quote">full synthetic 5w-30</TD></TR></TABLE>\
Why 5w-30 not 10w-30 ?
Old May 29, 2006 | 06:32 AM
paulwithap's Avatar
unless the temperature is gonna get real cold where you live in the next 3,000 miles, you don't need 10w-30. look in your manual.
Old May 29, 2006 | 06:41 AM
kornerk12's Avatar
Default Re: (paulwithap)
Wouldnt milage and engine wear be a factor also ? (I know he said his only has 40k but I just want to clear this up)
Old May 29, 2006 | 07:05 AM
AnthonyG2003
Guest
Posts: n/a
Default Re: (kornerk12)
Use 5w30 Synthetic....Once the engine gets over 75000 miles on it, then you might want to consider a different type of oil. You might also want to use the RED SEARCH button at the top right....It tends to make things a lot easier!
Old May 29, 2006 | 09:11 AM
maks's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by paulwithap &raquo;</TD></TR><TR><TD CLASS="quote">unless the temperature is gonna get real cold where you live in the next 3,000 miles, you don't need 10w-30. look in your manual.</TD></TR></TABLE>
You have the facts backwards
5W-xx is winter
10W-xx is summer
Old May 29, 2006 | 09:13 AM
flipwhip's Avatar
Default Re: (maks)
have got to agree
Old May 29, 2006 | 09:44 AM
MEAN88Si4WS's Avatar
Default Re: (flipwhip)
I use 10w30 in cold weather 5w30 in hot weather.... synthetic or regualr thats up to you and your wallet.
Old May 29, 2006 | 10:05 AM
b*saint's Avatar
Honda says all H22 oil gally's need 5w-30.
Old May 29, 2006 | 10:41 AM
maks's Avatar
Default Re: (BAD91Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BAD91Si &raquo;</TD></TR><TR><TD CLASS="quote">I use 10w30 in cold weather 5w30 in hot weather.... synthetic or regualr thats up to you and your wallet.</TD></TR></TABLE>
All I can say is... WOW... you guys should really do some research. Although whether you use 5W30 or 10W30, won't make much of a noticeable difference... especially in warm places like FL. If you're going to go through the hassle of using different grades based on temperatures... you might as well use the RIGHT ONE.
Again:
5W30 = winter
10W30 = summer
Why does this matter? The First number is an indicator of how easily the oil will crank at cold temperature. So, the lower the number, the lower your temperature can go, and the engine will still move.
Side effects, oils are modified using chemicals, if you use a winter oil in the summer, you won't notice a difference, however, there's a slightly higher chance of sheering.
Old May 29, 2006 | 10:51 AM
Default Re: (maks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by maks &raquo;</TD></TR><TR><TD CLASS="quote">
Again:
5W30 = winter
10W30 = summer
Side effects, oils are modified using chemicals, if you use a winter oil in the summer, you won't notice a difference, however, there's a slightly higher chance of sheering. </TD></TR></TABLE>
I believe that this is the best answer that i ahve gotten.. Thanks for the info. I was starting to come to the conclusion of useing 10w30 from what people in semi built cars around me use.... Appreciate the help
Old May 29, 2006 | 11:00 AM
DIRTYsouthBB6's Avatar
I hate " what oil should I use " threads
Old May 29, 2006 | 12:03 PM
Default Re: (DIRTYsouthBB6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DIRTYsouthBB6 &raquo;</TD></TR><TR><TD CLASS="quote">I hate " what oil should I use " threads</TD></TR></TABLE>
well then dont read them or post.... i needed some info quick and i was trying to find out what would be best.. So i decided to ask on here.
Old May 29, 2006 | 01:15 PM
98vtec's Avatar
moderator emeritus
Default Re: (PWRDbyHseries)
manual states 5w30 synthetic
Old May 29, 2006 | 05:14 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PWRDbyHseries &raquo;</TD></TR><TR><TD CLASS="quote">
well then dont read them or post.... i needed some info quick and i was trying to find out what would be best.. So i decided to ask on here.</TD></TR></TABLE>
I didn't mean any offense to you personally, I just hate these threads because I read sooo many of them
Old May 29, 2006 | 06:33 PM
petern101's Avatar
^agreed, you could have searched
djdownfawl
Honda Civic (2001 - 2005)
40
Apr 3, 2008 05:41 PM
TurboEG6
38
Aug 31, 2006 07:55 PM
S2000Forsale
Honda S2000
39
Oct 1, 2005 09:13 AM
Bbasso
Apr 22, 2003 03:55 PM
hybridEj6
Apr 16, 2003 02:57 PM
