Skunk2 Throttle Bodies?
Old May 28, 2006 | 10:31 PM
BoorishId's Avatar
Default Skunk2 Throttle Bodies?
I was looking at the skunk2 throttle bodies and noticed the the 66/68mm are the same price, yet the 60 and 70 are diffrent in price. I was just wondering if you were to purchase a a new throttle body wouldnt it be best to just get the 70mm for all aplications? to my understanding the bigger the throttle body the better right?
Old May 28, 2006 | 11:03 PM
H2290's Avatar
Default Re: Skunk2 Throttle Bodies? (BoorishId)
Bigger is definitely better if you are set up for it. A 70mm wouldn't help you much if your intake manifold is anything below that.
Old May 30, 2006 | 02:11 PM
BoorishId's Avatar
well how would you go about getting your intake manifold to be bigger, a machine shop? I searched around dont see any aftermarket manifolds for the f series engine.
Old May 30, 2006 | 03:02 PM
H2290's Avatar
I would personally check out MaxBore.com and forget the Skunk2 altogether.
Old May 30, 2006 | 09:19 PM
HONCORD's Avatar
Default Re: Skunk2 Throttle Bodies? (H2290)
Sweet site.
Glad you posted it.
Thanx.
Old May 30, 2006 | 09:55 PM
BlUAc's Avatar
Default Re: Skunk2 Throttle Bodies? (HONCORD)
I got a jg 66mm throttlr body and I just went down to home depot and got a gringing wheel and ported it out my self only spent lyk 5 bucks and my time
Old May 31, 2006 | 05:31 PM
BoorishId's Avatar
Default Re: Skunk2 Throttle Bodies? (BlUAc)
you grinded your own intake manifold? I mean using a die cutter or dremal isnt to hard but im thinking that **** is suppose to be really smoothe inside and ground a certain way. I just dunno if id trust not using like the toold machinist use, could be totally wrong though. I dunno to much about doing your own boring on stuff.
Old May 31, 2006 | 05:33 PM
BoorishId's Avatar
wow that place charges 165 for the intake and throttle body, good deal! Have you used them before?
Old May 31, 2006 | 10:08 PM
BlUAc's Avatar
naw its like the grind stone like on a benck grinder but small and shaped like an arrow with a lil bar to go in to a drill and then I got a some 500 grit wet sandpaper to smooth it out
Old May 31, 2006 | 10:43 PM
H2290's Avatar
MaxBore.com has a link on their site to Honda-Tech threads talking about them. They are pretty well like on this forum.
Old Jun 1, 2006 | 12:50 AM
iam7head's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoorishId &raquo;</TD></TR><TR><TD CLASS="quote">you grinded your own intake manifold? I mean using a die cutter or dremal isnt to hard but im thinking that **** is suppose to be really smoothe inside and ground a certain way. I just dunno if id trust not using like the toold machinist use, could be totally wrong though. I dunno to much about doing your own boring on stuff.</TD></TR></TABLE>
it's hard to do it perfectly, my shop manager call pull it off like it's nothing.
again, not something you want to do with your manifold if you have no experience.
plus, some people argue that the rough surface inside of the manifold is suppose to cut down the turbulence when the air is entering from the tb.
Old Jun 1, 2006 | 07:31 AM
BlUAc's Avatar
Default Re: Skunk2 Throttle Bodies? (iam7head)
for me it was actually pretty easy just keep a steady hand. And that rough surface i heard something along the lines of that also
Old Jun 1, 2006 | 10:24 AM
SuperSlow's Avatar
you do, of course, realize that if you are stock, this mod is not going to help you at all...
In fact, if you are not running cams and bump your compression or already have FI, this mod is a total waste.
But you know this already...
Old Jun 2, 2006 | 10:38 AM
BoorishId's Avatar
Default Re: Skunk2 Throttle Bodies? (SuperSlow)
Really? becuase when i this company makes this kit for my jeep that consists of a bored throttle body and an sri, they claim it adds like 20hp or some bs like that. I was thinking if anything a bored throttle body and intake would add a ton better throttle response if nothing else. Not really excpecting some crazy horsepower gain from doing it on a stock engine.
Old Jun 3, 2006 | 09:40 AM
BlUAc's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuperSlow &raquo;</TD></TR><TR><TD CLASS="quote">you do, of course, realize that if you are stock, this mod is not going to help you at all...
But you know this already...</TD></TR></TABLE>
uuh ya thats why i did a f22b1head swap with a port and polish a regrind cam milled a 30ths and a 3 angle valve cut. Witha custom turbo kit in the near future pushing bout 7lbs with a fmu
Old Jun 3, 2006 | 09:42 AM
BlUAc's Avatar
BoorishId check it out unless you go with a turbo app or all motor high comp you dont need a 70 mm tb the biggest you will benifit from is a 62 maybe 64mm tb
Old Jun 4, 2006 | 12:21 PM
BoorishId's Avatar
well the guy on max bore does F engines at 64mm not 70, so will that make a diffrence on a stock engine then? Im planning on doing some type of forced induction later down the road, im sure that it will definately help then but will i see any gains buy boring to 64mm on my stock engine?
Old Jun 4, 2006 | 12:24 PM
SuperSlow's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlUAc &raquo;</TD></TR><TR><TD CLASS="quote">
uuh ya thats why i did a f22b1head swap with a port and polish a regrind cam milled a 30ths and a 3 angle valve cut. Witha custom turbo kit in the near future pushing bout 7lbs with a fmu</TD></TR></TABLE>Uuh ya... that is why my comment was not directed at you..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoorishId &raquo;</TD></TR><TR><TD CLASS="quote">well the guy on max bore does F engines at 64mm not 70, so will that make a diffrence on a stock engine then? Im planning on doing some type of forced induction later down the road, im sure that it will definately help then but will i see any gains buy boring to 64mm on my stock engine?</TD></TR></TABLE>If I had to do 10 things for more power, bigger TB will be #8. You will not feel a difference on a stock engine... at all.
Old Jun 4, 2006 | 11:33 PM
BlUAc's Avatar
true but like I said if boost is in your future this may help
Old Jun 4, 2006 | 11:58 PM
SuperSlow's Avatar
If I had a list of 10 things to make power including boost, TB would be #8 as well.
Old Jun 5, 2006 | 06:29 AM
sportyaccordy's Avatar
I dunno if it's the same for 5th gens but on 4th gens if you get the dual runner bottom half you can put the H22/H23 plenum on your IM and get a Skunk2 throttle body...
Old Jun 5, 2006 | 11:22 PM
BlUAc's Avatar
Default Re: Skunk2 Throttle Bodies? (sportyaccordy)
well actually i just drilled out the holes to fit my im on my jg tb
95egianp
Mar 18, 2013 04:46 PM
949
Dec 3, 2008 03:06 PM
McFlurry
Jul 6, 2006 05:31 PM
gringo-gsr-01
Sep 11, 2001 04:47 PM
