rear disk swap question
Old May 28, 2006 | 07:37 PM
ef-b16sedan's Avatar
Default rear disk swap question
i bought a ef civic hatch (equipped with b16) for parts for my ef sedan. the hatch had the rear disk swap on it and i wanna put it on to my sedan. my question is does anyone know if the brake cables from the hatch fit the sedan? are they the same length? shorter? longer?
Old May 28, 2006 | 08:12 PM
SD_Lurker's Avatar
HT White Ops
Default Re: rear disk swap question (ef-b16sedan)
You should be fine.
Old May 28, 2006 | 08:47 PM
stockcivic103's Avatar
I have basically the same thing, but different cars, i have an 89 CVX Si with front disc rear drum, and a 90 CRX Si parts car with 4wheel disc brakes, and i wanna put the rear disc from the 90 on the 89, will i need anything?
Old May 28, 2006 | 09:17 PM
Default Re: rear disk swap question (stockcivic103)
as far as what you are swaping from crx to crx you shouldn't need anything, should just be a direct swap. only thing that i can think might be different would be the shocks
Old May 28, 2006 | 11:11 PM
CarAudioPro's Avatar
everthing is the same except for the ebrake cables. you cant use the ones from the drums. and the hatch ones are to short. a friend of mine had this problem, i believe he used cables from a 90-93 4-door tegy. i think. maybe i should have called and asked befor i posted this...ohwell
Old May 29, 2006 | 05:44 AM
crx_88_si's Avatar
Default Re: rear disk swap question (CarAudioPro)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stockcivic103 &raquo;</TD></TR><TR><TD CLASS="quote">I have basically the same thing, but different cars, i have an 89 CVX Si with front disc rear drum, and a 90 CRX Si parts car with 4wheel disc brakes, and i wanna put the rear disc from the 90 on the 89, will i need anything?</TD></TR></TABLE>
integra ebrake cables are longer than crx ebrake cables (cuz the car is longer, duh).
since both of your cars are CRX's, just swap over the trailing arms w/ athe brakes and use the 1990 crx si ebrake cables.
if you had a civic (hatch, sedan, wagon), you would need integra cables, but you dont, so go have fun.
Old May 29, 2006 | 10:34 AM
Default Re: rear disk swap question (crx_88_si)
i pulled the swap from a hatch and its going on my sedan. so u say i need the cables from a four door teg?
Old May 29, 2006 | 10:37 AM
crx_88_si's Avatar
try the hatch cables, worse case they dont work. not like you NEED a parking brake 100% of the time, just turn it off and leave it in gear.
Old May 29, 2006 | 05:07 PM
any idea as to where i can get some new trailing are bushings for cheap?
Old May 29, 2006 | 07:03 PM
Crx Jimmy's Avatar
get the trailing arm bushings from the dealer, i got them for $35 each
Old May 29, 2006 | 08:52 PM
mahatma's Avatar
Default Re: rear disk swap question (Crx Jimmy)
I am using ebrake cables from a 2dr DA teg on my sedan. fyi
john89crxsi
Mar 30, 2012 10:52 PM
skill178
28
Nov 3, 2011 09:33 PM
IP RACING
Jun 26, 2007 01:19 PM
ef-b16sedan
May 28, 2006 09:51 PM
