Air Conditioning gets warm at higher RPM's
Old May 28, 2006 | 05:21 PM
Wsteun's Avatar
Default Air Conditioning gets warm at higher RPM's
I recently picked up a 97 Prelude SH and I'm having an issue with the AC. It blows cold as hell when you're stopped, or the RPM's are anywhere below 2000. As the RPM's get higher, the air gets warmer. The fan doesn't slow down any, the air still comes out at the same speed, it's just warm. I don't think any of the major AC components are messed up. Could a belt be slipping? Or is it an sensor?
-Ward
Old May 28, 2006 | 05:40 PM
02 accord's Avatar
Default Re: Air Conditioning gets warm at higher RPM's (Wsteun)
You can rule out the belt slipping. That just wouldn't make sense. If the engine is spinning faster, why would the ac spin slower than at idle?
Old May 28, 2006 | 05:42 PM
Wsteun's Avatar
Default Re: Air Conditioning gets warm at higher RPM's (02 accord)
Cause if it's spinning faster, it can't grip as well?
Old May 28, 2006 | 05:45 PM
02 accord's Avatar
Ok, that would mean a little slippage. But not enough to slow it down below idle speed.
Old May 28, 2006 | 05:47 PM
Wsteun's Avatar
The rate at which the air is coming out remains constant. Temperature is what is changing.
Old May 28, 2006 | 06:15 PM
BlueLude94's Avatar
just be glad you ac works at all.
I am not sure about the preludes but there are some cars that disengage the A/C clutch for better accleration. Maybe that?????????
Old May 28, 2006 | 06:17 PM
Wsteun's Avatar
Default Re: Air Conditioning gets warm at higher RPM's (BlueLude94)
Don't think so. It's when I'm just cruising.
Old May 29, 2006 | 09:54 AM
MEAN88Si4WS's Avatar
automotive air conditioning systems frequently FAIL. Might be time for a charge with some dye in it to find leaks.
Old May 29, 2006 | 11:23 AM
SKDRCR's Avatar
Default Re: Air Conditioning gets warm at higher RPM's (BAD91Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BAD91Si &raquo;</TD></TR><TR><TD CLASS="quote">automotive air conditioning systems frequently FAIL. Might be time for a charge with some dye in it to find leaks.</TD></TR></TABLE>
yep
award78
Honda CR-V & Element
11
Sep 12, 2022 02:24 PM
johnehonda
May 26, 2010 02:42 AM
jackj
Jun 4, 2008 04:33 PM
EP_three
May 15, 2007 01:08 PM
darkfx
May 18, 2005 02:14 PM
