can someone please reply!!!!!!!!
Old May 28, 2006 | 03:01 PM
akteamster's Avatar
Default can someone please reply!!!!!!!!
i searched and i posted previously, but no one ever seems to reply to my threads!
can i use a 92 dx longblock which is MPFI with the DPFi manifold, obd0 dizzy and altenator in my 89 civic dx??????? i will keep the 89 dx cable trannnnnny.
i need a quick reply pleaseeeeeeee
Old May 28, 2006 | 03:06 PM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: can someone please reply!!!!!!!! (akteamster)
run dpi on a mpfi motor, i guess it could work...
I've re dpi a car and the wiring sucked.
Do you have a DPFI head around? Would be simpler to mate that to the b7 block.
Old May 28, 2006 | 03:14 PM
akteamster's Avatar
Default Re: can someone please reply!!!!!!!! (***-assin)
i have the complete DPFI motor, but its junk and i have a 92 dx MPFI motor lyin around so id figure i jus slap dat long block in........i dont want to convert to MPFI just yet as this will be a temporary fix
Old May 28, 2006 | 03:24 PM
Ass$nyper's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by akteamster &raquo;</TD></TR><TR><TD CLASS="quote">i have the complete DPFI motor, but its junk and i have a 92 dx MPFI motor lyin around so id figure i jus slap dat long block in........i dont want to convert to MPFI just yet as this will be a temporary fix</TD></TR></TABLE>
Well is the head on the dpi motor fragged? If the head is ok no reason not to just save yourself hassles.
The wiring you'll looking at will suck I am telling you that now.
http://www.rywire.com for mpfi, just get it out of the way if you can afford it.
Old May 28, 2006 | 03:46 PM
TREBLE's Avatar
yes you can, but i would strongly suggest you convert to mpfi.
Old May 28, 2006 | 03:52 PM
akteamster's Avatar
Default Re: (TREBLE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TREBLE &raquo;</TD></TR><TR><TD CLASS="quote">yes you can, but i would strongly suggest you convert to mpfi.</TD></TR></TABLE>
y do u strongly suggest that it be done right now?? i plan on converting to MPFI soon but just not yet, i would have to go hunting for injectors, resistor box, obd0 mpfi ecu and injector plugs which will run me about a $100 that i would liek to save right now.
i just want to do this for a temp fix....will the DPFI affect the motor's performance???????? as far as reliablity.... i need something to get me around for a month or two untill my friend gives me his 95 sohc vtec motor and then i will convert to MPFI
Old May 28, 2006 | 04:08 PM
SVOboy's Avatar
DPFI sucks, it'll make the 70 hp seem like even less, not to mention your intake charge will be fucked by different port sizes, but it'll work.
Old May 28, 2006 | 04:22 PM
akteamster's Avatar
Default Re: (SVOboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SVOboy &raquo;</TD></TR><TR><TD CLASS="quote">DPFI sucks, it'll make the 70 hp seem like even less, not to mention your intake charge will be fucked by different port sizes, but it'll work.</TD></TR></TABLE>
i can live with that for now, since it will only be a temp. fix jus to daily drive until i get the parts and time to convert to MPFI....thanks for the replies
Old May 28, 2006 | 06:25 PM
g-ride-si's Avatar
Default Re: (akteamster)
mpfi swap is easy, im sure you could find all the parts on here fairly easily and it will only take a cpl hours.
but if you want dpfi it will work.
Old May 28, 2006 | 07:48 PM
b18sihatch's Avatar
just multi point the motor dont fool with dpfi
Old May 28, 2006 | 07:57 PM
civicwagonman's Avatar
it'll get you by.
menappi
Jan 12, 2005 09:02 PM
wu tang
23
Aug 11, 2002 12:34 AM
hfracer420
Feb 12, 2002 07:54 AM
